Old 01-03-2018, 08:28 PM   #1
rogerkb1936
rogerkb1936's Avatar
Default who restores vacuum wipers?
thanx, roger
rogerkb1936 is offline   Reply With Quote
Old 01-03-2018, 08:57 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: who restores vacuum wipers?
Forget Model A wipers. Buy some RainX.
glenn in camino is offline   Reply With Quote
Old 01-03-2018, 09:34 PM   #3
1955cj5
1955cj5's Avatar
You could try this fellow....he may be able to direct you if he can't help...
http://www.wiperman.com/
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 01-03-2018, 09:50 PM   #4
blgitn
blgitn's Avatar
Yes, Ficken Wiper Service. I've used them several times with great results.
blgitn is offline   Reply With Quote
Old 01-04-2018, 01:21 PM   #5
steve s
steve s's Avatar
Ficken did mine about 20 years ago, and it's worked great ever since. Prior to that, when I was driving the car in high school, I took the wiper apart and greased its innards with some Lucky Tiger hair wax, which got it working again (the only luck the stuff ever brought me!).
steve s is offline   Reply With Quote
Old 01-04-2018, 01:33 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
You used too much! .........A little dab will do ya!
Old 01-04-2018, 11:49 PM   #7
steve s
steve s's Avatar
Different product, Tom, that was Brylcream--useless for my needs. You can't tell very well, but the "flattop" brush cut seen in my profile picture of me adding oil to my Ford took several dabs of something approximating axle grease to achieve the desired effect.
Alas, (unlike Bill) it's no longer a problem, although a few survivors are still trying to stay with the program.
Old 01-04-2018, 12:18 AM   #8
Larry Jenkins
Originally Posted by rogerkb1936 View Post
thanx, roger
John Holland in Ohio.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 01-04-2018, 11:42 AM   #9
rogerkb1936
thanx
Old 01-04-2018, 12:24 PM   #10
Robert/Texas
Robert/Texas's Avatar
Maybe it doesn't need restoring. When the wiper on my '34 roadster quit I sprayed a little WD40 into it and it started working again. This happened around 10 years or so ago and it still works. It doesn't do a very good job though.
Robert/Texas is offline   Reply With Quote
Old 01-04-2018, 01:20 PM   #11
Tom Wesenberg
I would use ATF rather than WD-40.
WD-40 is bad on potmetal, like the popout switch and wiper motors. It also messes up some plastics, like the divided plastic container I stored some bolts in, then sprayed them with WD-40 to prevent rust.
Old 01-04-2018, 05:33 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
BUT, at 82, how many can brag that they STILL have HAIR???
Bill Bushy
"THE ASSISTANT GURU OF STUFF"
Old 01-05-2018, 12:08 AM   #13
Larry Jenkins
Bill Bushy
Billy Bushy..
Going on 87 and still have a full head of (grey) hair..
Old 01-05-2018, 09:08 AM   #14
KGBnut
KGBnut's Avatar
Count me as a happy Ficken customer.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 01-05-2018, 09:27 AM   #15
Redbird
Redbird's Avatar
I used a couple drops of 3-1 oil and mine has been working since.
Redbird is offline   Reply With Quote
