Old 12-23-2017, 12:17 PM   #1
adileo
adileo's Avatar
Default Painting 52 f1 firewall
Hi guys
The firewall on my F1, is beat. The truck is a driver.
I don’t want to pull engine and am thinking an attempt to paint.
I’m thinking of using rust-o-lium flat black, with a brush.
I would like your thought / suggestions
File Type: jpg 8C20C3E1-2E64-40A6-A2FA-4B3654344AAB.jpg (71.3 KB, 72 views)
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 12-23-2017, 12:28 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Painting 52 f1 firewall
Remove as much wiring and other parts from the firewall as possible and wrap other nearby engine parts like steering column, etc with aluminum foil. Tape off the perimeter of the firewall and spray paint it. Brush will leave streaks and finish won't be as nice. I like acrylic enamel as it's easier to clean.
Old 12-23-2017, 02:51 PM   #3
Ford Freak
I would do as 19Fordy suggests , only I would look around for some red spray paint that is close to the truck color . If you have to go black , I would go w/a satin , or semi gloss , as it will look better than flat . Flat sometimes just looks like primer .
JMO - F F
Ford Freak is offline   Reply With Quote
Old 12-23-2017, 04:55 PM   #4
chap52
chap52's Avatar
Spray with Rustoleum Satin. The brush strokes will drive you crazy, and the spray is easier to touch up later. For real small touch-up I spray some of the paint onto a paper plate and use a small watercolor brush. Then I just throw it away. I always have a package of these somewhere in the shop.
chap52 is offline   Reply With Quote
Old 12-23-2017, 05:06 PM   #5
Ian1932
Ian1932's Avatar
Buy a pint of single stage urethane or single stage enamel. You can put it right over the old paint without priming unless its lacquer. Clean it with coleman fuel or = on a rag. the spray with silicon wax remover and wipe some more. scuff it with 400 and a red scotch brite the best you can. Tape everything with masking tape / grocery bags and spray away. It will hold up forever...Rustoleum will flatten in a short period of time and is not nearly as resilient to fuel and "stuff" A touch up gun will get in there real nice. Take off big items like battery and air cleaner...I did this on a 78 jeep truck for my friend and he drivers it all year, holding up nice.
Ian1932 is offline   Reply With Quote
Old 12-23-2017, 05:57 PM   #6
adileo
adileo's Avatar
Thanks guys - as always great advise
Thanks
Andy
1952 F1
Old 12-24-2017, 05:15 AM   #7
Ken Crans
Ken Crans's Avatar
I use the aluminum foil method saves alot of time around the wiring..thats an easy job you have,did a many engine compartments.
Ken Crans is offline   Reply With Quote
Old 12-24-2017, 09:59 AM   #8
rotorwrench
rotorwrench's Avatar
The vermillion red is available in spray cans for the Ford tractor guys since they used that color. Black hides the nasties a bit longer though.
Old 12-24-2017, 10:17 AM   #9
Capt Kirk
Capt Kirk's Avatar
If he wants to brush and wants black...how about POR frame paint? I used POR for the first time a couple months ago. Restored a 55 year old municipal fire hydrant with their red...brushed it on and turned out great.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 12-24-2017, 10:38 AM   #10
adileo
adileo's Avatar
I thought brushing would be better as there are some tight spots (like behind oil canister and worse yet the fuel pump).
But I also agree, I don’t want to look like my 8 year old grandson did it.
Ideal would be brush without brush marks, much like engine paint I used on my 39.
Thanks
Andy
1952 F1
Old 12-24-2017, 10:46 AM   #11
Ford whisperer
Ford whisperer's Avatar
After buying my f1 a dozen or so years ago I wanted to do a color change from white to meadow green because the factory white looked blah to me. The one issue that held me back from doing that color change was the firewall; I knew I'd have to pull the engine to do it right and feel good with the overall result. So after pondering the added workload of pulling the front clip and sliding out the recently rebuilt 8ba, I just bit the bullet and wound up disassembling the entire truck. Glad I did that. The end result was certainly worth the extra effort.
Ford whisperer is offline   Reply With Quote
Old 12-24-2017, 11:54 AM   #12
Ford Freak
This " tin foil over the wiring " is a great idea ! It is probably nothing new , but I had not heard it before . I will however, be trying it in the future !
Thanks & Happy Holidays - F F
Old 01-17-2018, 05:40 PM   #13
adileo
adileo's Avatar
Thanks guys!
File Type: jpg 43D365CC-17C4-4D50-BAE6-BAAB6D3AB7B8.jpg (67.0 KB, 69 views)
Thanks
Andy
1952 F1
Old 01-17-2018, 10:22 PM   #14
Ford Freak
Hey there you go ...... that looks good ! What sheen of black is that ? - F F
Old 01-17-2018, 11:42 PM   #15
TomT/Williamsburg
TomT/Williamsburg's Avatar
Any of the brush on engine paints will look great and leave no brush marks - KBS and Hirsh are two brands I have used ....
TomT/Williamsburg is offline   Reply With Quote
Old 01-18-2018, 08:02 AM   #16
30-9
Now that is much better. Nice job and also now protected.
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
