Old 12-14-2017, 08:05 PM   #1
1930deluxe
Default Primer on Motor
Do you need to primer the motor before painting? If so what color is used light gray, dark gray, black or red?
1930deluxe is offline   Reply With Quote
Old 12-14-2017, 08:08 PM   #2
JDupuis
JDupuis's Avatar
Default Re: Primer on Motor
I don't use primer for the engine.
Ford engine green is the proper colour. Available from all the vendors.
Good Luck. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 12-14-2017, 08:09 PM   #3
glenn in camino
glenn in camino's Avatar
I use one coat of rustoleum red rusty metal primer before two coats of my special mix of Ford engine green.
glenn in camino is offline   Reply With Quote
Old 12-14-2017, 08:24 PM   #4
jw hash
jw hash's Avatar
no primer, the engine paints of today go right over bare metal. just do NOT use any water base.
jw hash is online now   Reply With Quote
Old 12-14-2017, 08:28 PM   #5
redmodelt
redmodelt's Avatar
When it comes to heat transfer, less paint is better.
Old 12-14-2017, 08:59 PM   #6
Larry Jenkins
redmodelt's statement also applies to painting Model A radiators.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-14-2017, 10:32 PM   #7
Don Turley
Don Turley's Avatar
I only used primer on an engine one time, many many years ago. When the engine warmed up, the paint peeled. Never again! Only use paint that is intended for painting engines and apply it directly to clean bare metal. It is heat resistant. Most primers are not heat resistant.
Don Turley is offline   Reply With Quote
Old 12-15-2017, 12:12 AM   #8
1930deluxe
Thank all of you for your quick reply. This is the best site to use for information or problem solving on the Ford Model A.
Old 12-15-2017, 07:47 AM   #9
burner31
burner31's Avatar
I used a bio-degradable de-greaser, got the engine nice and clean, and painted the engine, no primer, has not peeled in the three years since.
I painted the intake manifold white, because I wanted to, there, answered your question.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 12-15-2017, 02:29 PM   #10
Purdy Swoft
Purdy Swoft's Avatar
Clean unpainted cast iron has tooth and needs no primer . I agree about heat transfer , keep the paint to a minnimum on engines and radiators !!!
