Old 11-19-2017, 08:03 PM   #1
kenwood7
Default Flathead Info.
I know I know this question has been asked many many times. But here goes.
This flathead came out of a 48 Woody. I have no additional info. as the owner passed away. On the top of the bell housing close to where the trans bolts is stamped the#4. Then up towards the manifold is a circle stamped and inside the circle is stamped clock wise 1j604. Then to the right of that circle id stamped X 7. Trying to attach pictures , but not have much luck.
kenwood7 is offline   Reply With Quote
Old 11-19-2017, 08:58 PM   #2
JSeery
JSeery's Avatar
Default Re: Flathead Info.
If you want me to post some photos for you email them to me: [email protected]
Old 11-19-2017, 10:39 PM   #3
JSeery
JSeery's Avatar
Ok, after having to re-setup my email account!
Old 11-19-2017, 11:29 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
The numbers are virtually useless.
Better off showing several views of the complete engine to get some idea as to the vintage and application.
Old 11-20-2017, 06:44 AM   #5
kenwood7
Ok thanks . I know that it is in the 42/48 range. Just did not know if the numbers meant thing.
Old 11-20-2017, 09:52 AM   #6
19Fordy
19Fordy's Avatar
Probably some kind of foundry casting info. from the pattern.
