Old 11-11-2017, 03:33 PM   #1
jim1932
jim1932's Avatar
Default 32 B steady rod holder question
Looks in the book like this assembly is black, while the top of the bellhousing is the engine color? Also, are these the correct bolt set up? Does anyone make the counter sunk bolt? I only have one.
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 11-11-2017, 04:20 PM   #2
Charlie Stephens
Default Re: 32 B steady rod holder question
I would check with Roy Nacewicz Parts, (734) 654-9450, fordbolts.com. If no luck get a allen headed one from a good hardware store and replace it later (I did this for my roadster back in the seventies). If you don't use the countersunk head on the drivers side the brake pedal might hang up on it.
Charlie Stephens
Old 11-11-2017, 05:28 PM   #3
DavidG
DavidG's Avatar
Jim,
The bracket should be painted black and the bell housing engine green. Let me know if Roy doesn't have the right countersunk bolt as I may have an extra. The set up in your photo is as original for that version of the bracket (there were three different versions).
Old 11-12-2017, 11:36 AM   #4
jim1932
jim1932's Avatar
I will call Roy Monday. I have an order sitting with him, hopefully this can be added.
Old 11-14-2017, 11:17 AM   #5
jim1932
jim1932's Avatar
Just to provide info.. Roy does not carry them. I need to check one more box to see if I have another one. Also, I have second bellhousing with a broken piece where one of the pins is. Can this be used with the broken piece? Or should it be junked?
Old 11-14-2017, 11:18 AM   #6
jim1932
jim1932's Avatar
Old 11-24-2017, 12:33 PM   #7
jim1932
jim1932's Avatar
Still looking for an answer for question above.
Old 11-24-2017, 07:27 PM   #8
62pan
There is enough of those flywheel housings around that I think I would save that one for a display motor. If you need to junk it bring it to Hershey next time you pass through and I will take it off your hands.
62pan is offline   Reply With Quote
Old 11-26-2017, 02:44 PM   #9
jim1932
jim1932's Avatar
Deal.
Old 11-26-2017, 03:37 PM   #10
DavidG
DavidG's Avatar
Evidently there wasn't enough 'beef' in that area of the bell housing casting as I checked the two that I have that aren't already in use and one is broken just like yours. Nice anchor for a big model boat.
Old 11-26-2017, 03:46 PM   #11
jimvette59
jimvette59's Avatar
Being an old machinist I would square it off and add a piece of steel with a threaded hole in it and use it . JMHO
jimvette59 is offline   Reply With Quote
Old 02-20-2022, 02:18 PM   #12
WRA
WRA's Avatar
I know this thread is a few years old thread but I found it researching this same problem.
Did you ever find a source for the special countersunk bolt? I’ve looked at 3rd Gen Bolts and nothing is listed as specific to the 32B
WRA is offline   Reply With Quote
Old 02-20-2022, 04:59 PM   #13
rockfla
rockfla's Avatar
What size thread is It? I have several sizes of flat head slot cap screws in stock BUT they are ALL course thread. IF it's a fine thread then so can't help!
Old 02-20-2022, 05:02 PM   #14
deuce lover
deuce lover's Avatar
They are available in allen head -fine thread.I got some off EBAY awhile back
deuce lover is offline   Reply With Quote
Old 02-20-2022, 05:18 PM   #15
WRA
WRA's Avatar
They are 1/2 x 13 with 3/4 Head.
Old 02-20-2022, 06:58 PM   #16
DavidG
DavidG's Avatar
They are N/C threads consistent with the Ford practice of using course-threaded fasteners into cast iron.
Old 02-20-2022, 09:35 PM   #17
Newc
Newc's Avatar
I found mine at a good Farm store. Newc
Old 02-21-2022, 12:06 PM   #18
Als48
Try McMaster-Carr. They have them in Hex Socket head style.
Als48 is offline   Reply With Quote
