Old 08-26-2017, 02:45 PM   #1
marc hildebrant
marc hildebrant's Avatar
Default Special Prep For Install of Water Outlet?
Group,
Down the road, I'm thinking of installing a different water outlet that has a drilled hole for a water temp probe. Since I just replaced the head gasket, I'm wondering if I will have a problem with my head gasket if I remove the front water outlet nuts and replace with a new water outlet ? Will I get a head gasket leak with the force removed and then reapplied ?
Marc
marc hildebrant is offline   Reply With Quote
