#1 |
I noticed my new tie bolt has a considerably thicker head than the original bolt I pulled from the spring pack. Should I file down the top of the head to be the same thickness as the original? Seems like if I used it as is it would hit against the bottom of the trunk floor before the spring fully seats in the crossmember.
