Old 08-05-2017, 07:05 PM   #1
Steve Plucker
Default Door Check Straps...
Most, if not all reproduction rubber "Door Check Straps" are black. Does anyone have a source for check straps that are the original brown color?
I find it strange that whoever is making these "black" straps, can't just change the color of the rubber to match the original color. AH but alas...it probably would cost that person much more money to produce by changing the color.
Thanks.
Pluck
Old 08-05-2017, 08:41 PM   #2
wrndln
Default Re: Door Check Straps...
Steve,
Richard Kilburn made some a while back. I bought a couple sets from him. I think Hunter Fanney also bought a pair for his Henry awarded 29 special coupe. His email 2 years ago was or is: [email protected]. I don't know if it is still current. The check straps were brown and even had the script F for Firestone on them. They looked real good.
Rusty Nelson
Old 08-05-2017, 09:47 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Only black front arm rests are reproduced for my 1950 Studebaker, and I never could find the correct brown ones, so I finally went to the auto parts store and bought a spray paint for vinyl, and it sure works great. It's the perfect color and match to the NOS rear arm rests. This is Bluebird Brown 154483
Old 08-05-2017, 10:11 PM   #4
Steve Plucker
Originally Posted by wrndln View Post
Steve,
Rusty Nelson
Thanks Rusty...Will give Richard an email.
Pluck
Old 08-05-2017, 10:13 PM   #5
Steve Plucker
Thanks Tom...It is to bad that there is not a process to "bleed" the black out of the black rubber then dye it dark brown!
Pluck
Old 08-05-2017, 10:14 PM   #6
PC/SR
Yo Pluck: I am on the performance side of the hobby but really respect and encourage you and the guys who do the restorations and want to keep history alive. 90 years from now my speedster will be gone, but I hope what you guys are doing lives on. (PS maybe my engine and running gear survive. (:-)). The color of the check straps is a pretty arcane matter, but should be preserved and I hope someone can find it.
PC/SR is offline   Reply With Quote
Old 08-06-2017, 06:31 AM   #7
2manycars
2manycars's Avatar
That works good on vinyl, which is pretty stable. I used it on arm rests for my MGBGT. I doubt if it would work on the door check straps, since they stretch when the door is opened, and bend when it is shut.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-06-2017, 07:04 AM   #8
lindy williams
Update on Richard Kilburn's e-mail. His new one is ([email protected])
lindy williams is offline   Reply With Quote
Old 08-07-2017, 03:23 AM   #9
pooch
pooch's Avatar
http://www.ebay.com.au/itm/1928-1931...wAAOSwPK5ZgG7f
Came across these ....
pooch is offline   Reply With Quote
Old 08-07-2017, 09:23 AM   #10
Steve Plucker
Originally Posted by pooch View Post
Thanks Pooch...but need the 8-1/2 inch type.
Again, why the maker of these black repros can not just change the color of the rubber and make them right is beyond me...probably cost to much to do so.
Pluck
Old 08-07-2017, 09:26 AM   #11
Steve Plucker
Thanks Lindy!
Pluck
Old 08-07-2017, 09:42 AM   #12
d.j. moordigian
d.j. moordigian's Avatar
Steve,
I found these...https://www.bobdrake.com/FordItem.aspx?Item=11A-7923504
Ya,..I know there the wrong length.....but?
d.j. moordigian is offline   Reply With Quote
Old 08-07-2017, 12:30 PM   #13
Tom Wesenberg
Several years ago at Hershey, I bought a pair of NOS brown straps for my 29 Tudor. I better measure them to see how long they are. I know they have the "F" for Firestone. I'll also see how the color compares to the ones I did for my Studebaker.
Old 08-07-2017, 02:42 PM   #14
TRP
That begs the question, what is the right length for a Tudor?
TRP is offline   Reply With Quote
Old 08-07-2017, 03:07 PM   #15
Bob C
If I'm reading the Standards correctly 8 1/2", with side mount spare 6 1/8".
Bob
Old 08-07-2017, 04:01 PM   #16
TRP
I don't have a side mount spare. So I'm guessing 8" is what I need.
I really need to get a set of these 'Standards' so I can 'learn to fish' (so to speak...)
Thanks!
Ted
Old 08-08-2017, 11:20 PM   #17
Tom Wesenberg
I just dug out my brown door check, and it's overall length is 8 1/2".
At the end of the rib pattern it says "PAT.JUNE 30, 1925" and under that is the letter "T".
At the other end is the letter "G".
I wonder if that stands for Goodyear?
Old 08-08-2017, 11:39 PM   #18
TRP
I checked that ebay link. They 6, 7, and 8" check straps. Just incase anyone was looking for longer brown straps.
Old 08-09-2017, 04:11 PM   #19
Don Turley
Don Turley's Avatar
Steve, I have one NOS strap, and three of the correct reproduction ones, 8-1/2", brown, Firestone logo. I was going to use them on a car that I was restoring for show, but that project got canceled.
I have attached two photos of the straps to this post. The first photo shows one side of the straps, then I turned them over to show the other side. In each photo, the strap at the far left is the NOS one and the other three are the reproduction ones. The reproduction ones look good on one side, however the opposite side has some flaws. I would have to say that the reproduction ones are "seconds", not "first quality". However, they were the only ones that I have been able to find of this length. I do not know who manufactured the reproduction straps, but I purchased them from another FordBarn member. I've had NOS of the shorter straps but have already sold them.
Don Turley is offline   Reply With Quote
Old 08-09-2017, 05:52 PM   #20
Tom Wesenberg
Here's my original door check strap and the Studebaker arm rest I changed from black to brown.
As you can see, the strap is darker. I'll have to see if the parts store has the right color.
