Old 08-04-2017, 06:55 PM   #1
V00DY
Default 53 Monarch. Engine miss smooths out on acceleration
My 53 Monarch is a daily driver. Lately it has begun to miss at any cruising speed. However, when I accelerate, even slightly, the miss goes away. As soon as I feather the throttle the miss comes back. That suggests to me that it has something to do with the vacuum advance, but I don't know what or how.
V00DY is offline   Reply With Quote
Old 08-04-2017, 07:30 PM   #2
RalphG
RalphG's Avatar
Default Re: 53 Monarch. Engine miss smooths out on acceleration
I'm sure we would like to see a picture of the Monarch. On my 52 Merc I had some missing and cutting out issues and I found the wire from the distributor to coil was nearly broken off at the dist. end. New wire and ends had it running smooth again. Just a thought I had when you mentioned your problem.
RalphG is offline   Reply With Quote
Old 08-05-2017, 05:47 AM   #3
Kojack
Inspect the wire under the point plate for fraying or rub thru and grounding when the vacuum advance pulls/moves the plate.
Kojack is offline   Reply With Quote
Old 08-05-2017, 06:07 AM   #4
Mart
Mart's Avatar
See if pulling the choke out (if it has one) smooths it out. Could be a blockage in a main jet and it's ok once the power valve opens. Could be ignition related though.
Old 08-05-2017, 06:16 AM   #5
flatheadmurre
flatheadmurre's Avatar
Blocked low speed passages in carb so it gets lean or that it gets to rich from broken powervalve...First do as Mart says and check with choke that will give you a hint if it´s fuel or ignition related and if running lean.
Old 08-05-2017, 08:03 AM   #6
KGS
KGS's Avatar
X2!
I had the same problem on my '51. Replaced the wire, problem solved.
Ken
KGS is offline   Reply With Quote
Old 08-05-2017, 02:29 PM   #7
V00DY
Hi guys:
Thanx for the ideas. Haven't tried any of them yet but first here is a picture of my Monarch. https://www.facebook.com/media/set/?...4922214&type=3
Old 08-05-2017, 07:45 PM   #8
RalphG
RalphG's Avatar
I have to say that is a beautiful Monarch.
