Old 07-06-2017, 07:31 PM   #1
michael a
michael a's Avatar
Default Have any of you tried the patronix distributor
I have been thinking about 1 very seriously who wanted someone's opinion
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 07-06-2017, 07:45 PM   #2
denis4x4
denis4x4's Avatar
Default Re: Have any of you tried the patronix distributor
Been using Petronix in my classic cars, Model A's and boats for 30 years. The only issue I had was self inflicted. Use the search function and you will find some detractors as well as people like me that think they're great. Research it and make your own decision.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 07-06-2017, 07:49 PM   #3
denniskliesen
denniskliesen's Avatar
The last time I looked into a Pertronix, they informed me that they did not offer their unit, but only to vendors that make a kit for the Model A. They suggested FSI and that they make a very nice kit. I know now there are others but I don't remember the names...
denniskliesen is offline   Reply With Quote
Old 07-06-2017, 08:13 PM   #4
48fordnut
48fordnut's Avatar
I have used several and with great success..
48fordnut is offline   Reply With Quote
Old 07-06-2017, 08:23 PM   #5
29spcoupe
29spcoupe's Avatar
I used one on a 41 Packard, liked it very much. I used the hotter coil with it.
29spcoupe is offline   Reply With Quote
Old 07-06-2017, 09:50 PM   #6
mike657894
mike657894's Avatar
when I was thinking about buying a new dizzy I was having running problems. IT turned out to be intake leaks exhaust leaks and head gasket blown on the two back cyls giving 30 min of ok running then sputter then full stop no spark till the next day. the plugs were getting wet. And i couldn't time my car properly due to intake leak. Once my engine was good the old stuff with a tune up kit and a setting just advanced slightly of the nurex timing wrench my car is running great and tuned easily.
mike657894 is offline   Reply With Quote
Old 07-06-2017, 10:00 PM   #7
RawhideKid
I just returned from our regular Thursday evening cruise where a load of non-A folk wondered what the hole in the radiator was for. So, with a stock ignition car, I pulled out the crank, slipped it in the hole, turned on the gas and ignition switch and with a ¼ crank fired the critter right up as they all stood in awe.
I personally see no reason to deviate from the stock distributor.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 07-06-2017, 10:51 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Modern is better!
Old 07-06-2017, 11:22 PM   #9
denniskliesen
I have a pertronix in my 46 Dodge pickup. Often I wonder how much better it would be in my A. It sure woke up my old pickup. No more checking gap and replacing points. No more condensor problems...
Old 07-11-2017, 06:33 PM   #10
Don S
I have a FSI Zipper,complete,used a month,but was too advanced for my Brumfield Head,needing only 18 degrees max advance. Pm me if you are interested.
Don S is offline   Reply With Quote
