Old 06-15-2017, 09:05 PM   #1
Greezybob
Default E brake.
I have a 29 frame that is missing the holes in the frame for the ebrake rod crossmember that connects the rods to the rear brakes. Can any one tell me what I have?
Greezybob is offline   Reply With Quote
Old 06-15-2017, 09:26 PM   #2
PatrickGrant
PatrickGrant's Avatar
Default Re: E brake.
Have a picture of the frame ? Early 28 frame ?
PatrickGrant is offline   Reply With Quote
Old 06-15-2017, 09:47 PM   #3
Greezybob
The frame number is A155xxxx
I'm new to this site so I need to figure out how to add a pic.
Old 06-15-2017, 09:56 PM   #4
PatrickGrant
May 1929. You are correct. Have you been to plucks site for frame changes ? Try "Go advanced" for picture loading.
Old 06-15-2017, 10:08 PM   #5
Greezybob
The hole with the blue pen is where the big rod sticks out both sides of the frame.
Old 06-15-2017, 10:15 PM   #6
PatrickGrant
Greezybob, at least I helped you load pics ! The real techs should be responding soon. I'm just the greeter tonight Check out plucks site, that's where I'm heading now. Pat
Old 06-15-2017, 10:20 PM   #7
Greezybob
This is a 31 frame. That's the rod that needs to go where the blue pen is in the other picture of the 28 frame
Old 06-15-2017, 10:22 PM   #8
Greezybob
Ok thanks for the help on the pics.
Old 06-15-2017, 10:25 PM   #9
1955cj5
1955cj5's Avatar
This is a 29 frame....three holes. Two bolts hold a cup on the inside of the frame that the brake cross shaft rotates in...center hole for a grease fitting...you can see the brake actuating arms go around the frame bottom
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 06-15-2017, 10:30 PM   #10
1955cj5
1955cj5's Avatar
This is the cup inside the frame rail..
http://www.snydersantiqueauto.com/cr...-brackets-4304
Old 06-15-2017, 10:34 PM   #11
Greezybob
That's some good information. Thanks 1955cj5. I need to find the mechanism for the 29 e brake or can I use the 31 mechanism parts if I drill out the middle hole in the frame?
Old 06-15-2017, 10:36 PM   #12
PatrickGrant
Might be like the early frames yet, see cross shaft leaning on pole behind frame ? bolts on inside of frame with three holes, 2 for bolts and center for zerk.
Old 06-15-2017, 10:38 PM   #13
PatrickGrant
Thanks 1955 !!
Old 06-15-2017, 10:39 PM   #14
1955cj5
1955cj5's Avatar
I don't know about that....I would look for the original style parts...you might have fit issues down the road with the 31 cross shaft....but that is just a guess...
Old 06-15-2017, 10:47 PM   #15
Greezybob
I see the diferance in the two styles. I will be on a quest to find the right parts Thanks for all the help Good night.
Old 06-15-2017, 11:21 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
Call Bert's in Denver for the right parts. 800-321-1931
I like the 28-9 style much better, because it's easier to service.
Old 06-15-2017, 11:59 PM   #17
SeaSlugs
SeaSlugs's Avatar
I like the 29-9 style much better, because it's easier to service.
agreed - i can tell just by looking at it its easier to service....
Yup berts im 100% sure would have what your looking for. Check the swapmeet area on the forum too - its one of those parts that virtually cant go bad so theres thousands of them out there.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-16-2017, 09:15 AM   #18
Greezybob
I will check that out. Thanks.
Old 06-16-2017, 09:35 AM   #19
zzlegend
zzlegend's Avatar
zzlegend is offline   Reply With Quote
