Old 05-27-2017, 12:46 AM   #1
Floats
Floats's Avatar
Default V8 front axle
Hi Guys,
I was offered a V8 front axle as replacement.
Is the V8 front axle the same as the Model A axle?
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 05-27-2017, 02:39 AM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: V8 front axle
No. The early ones have a drop, and the later ones are wider as well
Old 05-27-2017, 09:22 AM   #3
Floats
Floats's Avatar
TKS Chuck,
Much appreciated.
Regards
Chris
Cape Town
Old 05-27-2017, 09:36 AM   #4
Fordors
Do you know the year of the axle and also what are your plans? Will brakes remain mechanical or be hydraulic?
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 05-27-2017, 10:48 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ted has a TUBE axle from a '37 V8-60, under his '30 Coupe.
I understand that they were dropped, to compensate for the lighter V8-60.
Bill Isawit
"THE ASSISTANT GURU OF STUFF"
Old 05-27-2017, 02:43 PM   #6
Jim Brierley
32-34 axles will bolt right in and lower the front of the car about 1/2". Later axles have the spring perch bolts farther apart, so the A spring won't fit. 32-34 brakes are bigger (12" diameter) and can be hooked up to the A, giving a little better brake.
Jim Brierley is offline   Reply With Quote
Old 05-27-2017, 09:03 PM   #7
Floats
Floats's Avatar
Thanks Guys,
No, I am not planning to do any mods or 'upgrades'
I was led to believe my axle might be bent and was offered a V8 axle by a friend. So, if it is not a straight swop, I can live with a slight kink. It does not really bother me.
I need to replace the RH kingpin bushes and thought it might be a good time to swop the axles.
Thanks, much appreiated.
Regards
Chris
Cape Town
Old 05-28-2017, 11:53 PM   #8
Manager
Manager's Avatar
You will straighten the axle fairly easily just cold with a press if you take it out.
Manager is offline   Reply With Quote
Old 05-29-2017, 06:27 AM   #9
Charlie Stephens
An alignment shop that works on big trucks may have the equipment to straighten the axle in the car.
Charlie Stephens
Old 05-29-2017, 01:41 PM   #10
Floats
Floats's Avatar
TKS Gents,
Yep, I found a truck shop that will take a look.
Much appreciated.
Regards
Chris
Cape Town
