Old 05-01-2017, 08:37 PM   #1
Steve in Tampa
Default Fire wall 1932 truck
Need pictures of model B fire wall to show location of assorted wiring,pedal,speedo cable , dist wire, etc thanks steve
Steve in Tampa is offline   Reply With Quote
Old 05-01-2017, 09:07 PM   #2
Charlie Stephens
Default Re: Fire wall 1932 truck
steve,
You should be able to find what you need in "The 1932 Ford Book" from the Early Ford V8 Club, https://www.earlyfordv8.org/Shop.cfm?id=15&pid=2 The pickup truck should have the same firewall as the passenger car. It will also contain answers to other questions that you didn't even know you had.
Charlie Stephens
Old 05-01-2017, 09:36 PM   #3
Steve in Tampa
I have those books 1, 2 They are great ,but i need more detail on the wall. thanks, steve
Old 05-01-2017, 11:06 PM   #4
DavidG
DavidG's Avatar
Please refer to the colored photos of the B engine compartment in Chapter 5. Between the two of them you'll see where everything is routed and/or attached.
Old 05-02-2017, 07:30 AM   #5
Steve in Tampa
Thanks,I have seen those pics and they are hard to see details in the book, dark, and they are more focused on engine rather than wall. Need a different angle straight at wall ,showing a little of the side of engine and more toward wall . sorry to be a pain .
Old 05-02-2017, 07:45 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
Steve, I owned an original '32 pu a little over ten years ago that I had taken many pictures of. If you pm me your email address, I would send you any pictures I have of the firewall area.
John
Old 05-03-2017, 06:36 PM   #7
Steve in Tampa
I sent you a message to send pics, maybe you did not get it. e-mail [email protected]
Old 05-04-2017, 09:02 AM   #8
32B
32B's Avatar
if you tell me specifically what you need I can take pics. my wiring is no good, but anything else.
32B is offline   Reply With Quote
Old 05-08-2017, 12:42 PM   #9
jerseyboy
jerseyboy's Avatar
Steve,
These might help, I've collected a lot of images for my work on my wagon. These are from a 32 woodie in Oregon.
Keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 05-08-2017, 03:12 PM   #10
DavidG
DavidG's Avatar
With respect, if the objective is originality, there's a lot going on in those two photos that is misleading.
Old 05-12-2017, 12:45 PM   #11
Steve in Tampa
Thanks to all I think I got it figured out. there is alot going on and alot of holes. Anybody know what the clinch nut (5/16 fne thread) on the driver side fire wall is for ????? Thanks, Steve
Old 05-12-2017, 01:29 PM   #12
Charlie Stephens
Do you mean the hole in the first picture that is located about 8 inches from where the never adopted vacuum was to be mounted? If no how about a picture. If yes I assume that it was for the vacuum operated clutch. The second photo shows the same threaded hole in a later firewall. DO NOT use these photos for other information as the cars are neither restored or original.
Charlie Stephens
Old 05-12-2017, 04:33 PM   #13
Steve in Tampa
yes that is the one , thanks, steve
Old 05-15-2017, 07:48 AM   #14
jerseyboy
jerseyboy's Avatar
David,
Thanks for keeping me informed. I appreciate your knowledge for 32's.
For gas somehow,
