Old 04-27-2017, 08:06 PM   #1
Fillinjc
Fillinjc's Avatar
Default Manifold Stud Torque
Hi,
Installing a new intake on my 1930 coupe. Using studs and brass nuts I installed a year ago with the engine rebuild. I was torquing to 30 ft lbs. As I was finishing, the front stud began creaking to beat the band. Not even sure where the torque ended up. I am thinking to redo them using Anti-Seize. Les Andrews book says reduce torque by 45% using Anti-Seize. Torque to 17 ft lbs?
Thanks,
Jerry
Fillinjc is offline   Reply With Quote
