Old 04-23-2017, 08:01 PM   #1
Mike..Yorba Linda
Default 36 radiator in correct position
Can anyone please post a photo of the top side mount where it attaches to the radiator? I had mine recored and I think the radiator is too high. It looks like it can go down 3/8" and my hood would fit better. Everything fit great before I had the work done. See photo....Thanks....
Mike..Yorba Linda is offline   Reply With Quote
Old 04-23-2017, 08:07 PM   #2
Gary Tosel
Gary Tosel's Avatar
Default Re: 36 radiator in correct position
Photo of the original type bracket and grille attachment for 36 Ford
Gary Tosel is offline   Reply With Quote
Old 04-23-2017, 08:20 PM   #3
Mike..Yorba Linda
Thanks Gary, just what I need to show the guy. That bend in the mount needs to follow the tank, that's what I thought....
Old 04-24-2017, 10:34 AM   #4
blucar
blucar's Avatar
Comparing the two pix it is quite obvious that the guy that did the new radiator really screwed the side mount (s) up. It could be that the core in the new radiator is not correct.
Bill.... 36 5 win cpe
Old 04-25-2017, 07:15 PM   #5
Mike..Yorba Linda
That's what happened. I took it back and he's willing to correct it. Does someone have the measurement from the bottom of the mounting tab to the top tank crease? I can tell him that's what I need for it to be right....Thanks....
Old 04-26-2017, 09:18 AM   #6
rotorwrench
rotorwrench's Avatar
Looks like the core was cut a bit too long. Measure twice & cut once applies to that stuff too. The old Fords count on that stuff being right for all the front sheet metal to fit right. It doesn't just bolt to a core support like later ones.
Old 04-26-2017, 09:27 AM   #7
JSeery
JSeery's Avatar
Wouldn't you want the measurement from the bottom mount? The tank may or may not be in the original position.
Old 04-26-2017, 11:16 AM   #8
Mike..Yorba Linda
I've talked to my radiator guy. He needs the measurement between the top and bottom "header" or between the tanks. If I could get a few measurements to verify that would be great. Thanks Guys/Gals for your help.....
