Old 04-16-2017, 04:05 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default Ignition woes (Again) Burnt Coil?
So I was finishing up the transmission job, took it for a short ride and it performed perfectly. I guess I solved that jumping out of 3rd gear Problem. I parked it in the driveway.Came out from cleaning the garage to put it away, NO START. What the hell is this, No spark! I was just down the road with this about six months ago, thought I had it fixed once and for all! I guess not! So I get the meter and check the coil. Now as I understand it, I should have voltage on both sides of the coil. I have voltage on one side only. Did I burn the coil?
Terry
Terry, NJ is offline   Reply With Quote
