Old 04-15-2017, 09:39 PM   #1
gary678*
Default 12 volt horn
New to the Model A hobby . I have a 12 volt horn that does not give full sound. Can these be rebuilt ? [email protected]
gary678* is offline   Reply With Quote
Old 04-15-2017, 10:12 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 12 volt horn
Is it the style with the chrome trumpet?
Old 04-15-2017, 10:15 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by gary678* View Post
New to the Model A hobby. I have a 12-volt horn that does not give a full sound. Can these be rebuilt? [email protected]
Welcome to the hobby and to Fordbarn.
The rebuilding of the horn depends a lot on what type of horn you have to start with. The horn for the Model A were all 6-volt horns so your horn has been rewired or you have an aftermarket horn. Do you have pictures of the horn with and without the cover removed that you can show us?
Old 04-16-2017, 07:35 AM   #4
pgerhardt
pgerhardt's Avatar
It depends. If your horn has two screws on the back of the cover (one holds on the cover - the other is for adjusting the sound) then the cover can be removed and the horn serviced. If not then check the metal diaphragm. from the front (you have to pop out the screen). There may be an adjustment screw you can mess with. If you have neither it is time to find new horn. You could use a real 6 volt model A horn with one of the resistors sold by the venders that reduces your 12 volts to 6 volts.
I see you are from NY. I will be at the Cider Mill model A & T show in May with a good selection of horns (early Sparton with the flat screen, later Spartan, AIMs, Stewart Warner, 32 Sparton, and 32 beeper). I even have an old 12 volt after market horn you could have for free.
File Type: jpg Screen Shot 2017-04-16 at 8.39.07 AM.jpg (58.5 KB, 28 views)
pgerhardt is offline   Reply With Quote
Old 04-25-2017, 01:54 PM   #5
rocket1
Rhinebeck N.Y.show and flea,first weekend in May,antiques on Sunday,you will find alot of help there from the "A" people.
rocket1 is offline   Reply With Quote
Old 04-25-2017, 02:43 PM   #6
gary678*
Thank you for the quick reply! G.Dross
