Old 03-27-2017, 06:51 AM   #1
Talkwrench
Talkwrench's Avatar
Default Valve retaining clip
I have removed all the valves on this 37 engine no problems except the last one no. 7 intake clip Just won't come out, It's very loose but won't pop out. I've tried tapping it above the clip, yes I have made a wire puller, even have a heavier hook ( radiatior hose remover) squirted it, tapped this way, that way but it won't come off the guide. I'm worried if I keep working it I'll snap the tag of and then I'll really be in trouble.. Should I just try take the cam out and will the lifter just fall out and keep at it ? Any further tricks?? Frustrated..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
