Old 03-15-2017, 08:49 AM   #1
lenmissy
Default gas filter
What is a easy way to change gas filter on my 1940 ford without getting gas all over The tank is full.
lenmissy is offline   Reply With Quote
Old 03-15-2017, 09:28 AM   #2
19Fordy
19Fordy's Avatar
Default Re: gas filter
Where is the filter located?
Buy one of the siphon hoses and empty the tank into another vehicle.
If the line into the filter is rubber, clamp it with a pair of vise grips. Then remove the filter.
Remove the filter and quickly plug the line with a piece of hose plugged with a bolt. You will loose some gas but you can catch it with rags.
If the car is drivable drive it until tank is empty.
The OEM had a drain plug. You could empty the tank into three 5 gallon buckets. Don't store them inside.
Old 03-15-2017, 01:18 PM   #3
lenmissy
6 inches from gas tank.
