Old 03-10-2017, 04:02 PM   #1
the human wrench
Default Lightweight Brake Drum
1933/34 Ford?
Miracle Engine Rebuilders. "If it runs, it's a Miracle!"
the human wrench is offline   Reply With Quote
Old 03-10-2017, 04:07 PM   #2
Brian
Brian's Avatar
Default Re: Lightweight Brake Drum
32-34 Ford
Unfortunately, two half wits don't make a whole wit!
Brian is online now   Reply With Quote
Old 03-10-2017, 04:17 PM   #3
Charlie Stephens
Here is a good reference, http://www.fordgarage.com/pages/V8brakedrums.htm. Brian must have very good eyes. I can't tell if it is 11 inch (1931 model A) or has multiple grooves on the outside (1935).
Charlie Stephens
Old 03-10-2017, 04:34 PM   #4
VeryTangled
VeryTangled's Avatar
Hi Everyone. Here's a couple of shots of Don Rogers' V-8 Club restoration guide that is a super-great resource! https://www.earlyfordv8.org/Shop.cfm?id=18&pid=2
I'm certainly not good at identifying parts. But, might also be a '35 front as seen in the second photo?
Can we get another shot showing the outer edge to see if there are rings?
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 03-10-2017, 05:22 PM   #5
PeterC
PeterC's Avatar
Originally Posted by the human wrench View Post
1933/34 Ford?
I have these open brake drums as stock on my 1935 coupe
PeterC is offline   Reply With Quote
Old 03-10-2017, 07:07 PM   #6
AnthonyG
AnthonyG's Avatar
Me too' front brakes on my '35 Tudor Slant
Nomad
AnthonyG is offline   Reply With Quote
Old 03-11-2017, 12:20 AM   #7
JWL
I have found them on 36 also.
JWL is offline   Reply With Quote
Old 03-11-2017, 12:35 AM   #8
tubman
tubman's Avatar
Really? I have never seen any. I would think that this type of design would not
lend itself to the wide five pattern. You learn something new every day! I would think they would be quite scarce.
tubman is online now   Reply With Quote
Old 03-11-2017, 09:42 AM   #9
AnthonyG
AnthonyG's Avatar
I was in another thread discussion about rarity of '35 drums in that the design is 1 yr. only. Guess these are even more rare?
Nomad
Old 03-11-2017, 09:55 AM   #10
DavidG
DavidG's Avatar
How did a question about a '32-'34 brake drum end up being a discourse on very obviously different '35 drums and then again another leap to '36 drums?
Old 03-11-2017, 10:27 AM   #11
tubman
tubman's Avatar
Simple. The topic is "Lightweight Brake Drum", which is fairly generic. The O/P asked if the one pictured was "1933/34". To those of us who are not experts, it may have well been 1932/35. I also find that it interesting and germain that '36 wide fives were made with the same open design. The '35's may be "very obviously different" to you, but not to me and probably a lot of others.
Old 03-11-2017, 10:51 AM   #12
DavidG
DavidG's Avatar
The difference is pretty straight forward. The '35 has cooling fins and the '32-'34 has none as shown in the photos in #1 and #4.
With respect, what's generic about the question "1933/34 Ford?"?
Old 03-11-2017, 12:02 PM   #13
AnthonyG
AnthonyG's Avatar
Seems to me "the human wrench" was asking whether it was a '33 or '34 and the '35 came into the conversation as a result of "VeryTangled" introduced the Info sheet indicating it was a 1935 introduction. The discussion was titled "Lightweight Brake Drum" and not that it's an issue but additional Info about the cooling rings on the solid style was added info from the Info sheet. Possibly the drum shown in the original pic is neither a '33 or '34 but a later year, '35? Pretty easy to see the interest in the thread got a bit more inclusive as the discussion show additional detail.
Nomad
Old 03-11-2017, 02:10 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Well, since '36 was mentioned here, this might be a good time to point-out that NORMAL '36 front drums ARE what we refer to as having the "WIDE 5" bolt pattern, and that they also have that goofy, long snout that the outer bearing rides in, as seen on the left in this pic. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-11-2017, 02:29 PM   #15
Mart
Mart's Avatar
There is another drum in the background of the original pic, which clearly only has one ring, this appears to be a match to the main subject of the pic, so as stated, they are 32-34 drums.
Mart.
Old 03-11-2017, 03:55 PM   #16
VeryTangled
Originally Posted by Mart View Post
There is another drum in the background of the original pic, which clearly only has one ring, this appears to be a match to the main subject of the pic, so as stated, they are 32-34 drums. Mart.
As I looked at the original post again, I saw what Mart saw and what I didn't see the first time I looked, the drum in the background.
-Jeff H
Old 03-11-2017, 03:58 PM   #17
V8COOPMAN
V8COOPMAN's Avatar
John.......Are these possibly the "open-window" drums you found on a '36? DD
T5 W/TORQUE TUBE
Old 03-11-2017, 04:14 PM   #18
Andy
I had a set of those on a 35-36 rear end. Very strange. Are they early 36??
Andy is offline   Reply With Quote
Old 03-11-2017, 05:48 PM   #19
cas3
i have ONE also, certainly not ford?
Old 03-11-2017, 07:21 PM   #20
Mart
Mart's Avatar
They are 36 drums, I assume the "early 36" assertion is correct. They are factory fit ford parts for at least part of the 36 model year. I'm talking about the last pic shown, not the first.
Mart.
