Old 03-09-2017, 09:43 AM   #1
sam03
Default 226 Fan/Alternator hitting each other
Is anyone running a ford 226 flathead? I have a 51 226 in my 51 F3 i added an alternator but the fan really close to hitting the alternator. I thinking on making a aluminum spacer for the fan but wanted to see if there were any work around that y'all have already found.
1951 F3
sam03 is offline   Reply With Quote
Old 03-15-2017, 08:20 AM   #2
sam03
Default Re: 226 Fan/Alternator hitting each other
No one ran into this problem? What am i missing?
1951 F3
Old 03-15-2017, 08:32 AM   #3
toby
toby's Avatar
I used washers between the fan and pulley because the fan was too close to the fan belt. See pic of my setup.
toby is offline   Reply With Quote
Old 03-15-2017, 08:34 AM   #4
toby
toby's Avatar
Another pic of my setup.
Old 03-15-2017, 08:35 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
If it's "close to hitting the alternator" and not hitting the alternator, what's the problem?
And if it worries you, do what needs to be done to eliminate the worry.
Then you can advise others as to what you did.
Old 03-15-2017, 11:35 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
That alternator appears to be mounted too far rearward, as the belt seems to be meeting the alt pulley at an angle. That could easily throw the belt, if I'm seeing this correctly. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-15-2017, 01:13 PM   #7
JSeery
JSeery's Avatar
Sure looks like it is too far aft!
Old 03-15-2017, 01:23 PM   #8
cmbrucew
cmbrucew's Avatar
Might be the wrong fan, V8 maybe. Belts look out of alignment.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-15-2017, 01:53 PM   #9
toby
toby's Avatar
My setup has been working for almost 10 years without throwing or wearing out a belt. The alignment is a tad off. It was the best a guy could do without any product available for the 226 6.
Old 03-15-2017, 02:02 PM   #10
jagnweiner
jagnweiner's Avatar
It's a purty engine.
Regards,
Scott
'47 Mercury Convertible
'25 Dodge Bros. Touring Car
'63 MG Midget
jagnweiner is offline   Reply With Quote
Old 03-15-2017, 03:55 PM   #11
G.M.
Looks like the alternator is mounted to far FORWARD. This makes the
belt look like it's back to far. The alternator belt seems to line up with
the crank shaft pulley. G.M.
www.fordcollector.com
Old 03-15-2017, 04:00 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Do WHAAAT? DD
T5 W/TORQUE TUBE
Old 03-15-2017, 05:27 PM   #13
41Joe
41Joe's Avatar
Toby,
Did you make the bracket yourself? I have a 226 and am going to put an alternator on it. I found a bracket kit, but I am not into it. I was wondering what else is out there.
41Joe is offline   Reply With Quote
Old 03-15-2017, 09:30 PM   #14
toby
toby's Avatar
I originally made my own bracket before one was available. This bracket is from the Mac's kit. The bracket is similar to one for an alternator conversion for an 8/9N Ford Tractor. The arm to keep tension on the alternator is a generic alternator bracket.
Old 03-16-2017, 07:09 AM   #15
G.M.
Originally Posted by V8COOPMAN View Post
Do WHAAAT? DD
Straighten the alt and move it back so the pulley's and belt
line up. G.M.
Old 03-16-2017, 10:00 AM   #16
51 MERC-CT
51 MERC-CT's Avatar
line up. G.M.
Wow! Guess I must be seeing things or it's an optical illusion
Old 03-16-2017, 11:45 AM   #17
G.M.
Look at the bolt on the bottom front of the alternator, that don't
look forward compared to the top?? G.M.
Old 03-16-2017, 11:48 AM   #18
JSeery
JSeery's Avatar
Don't you want the belt pulleys to line up, not the bolts? The alternator appears to be mounted considerably aft of where it needs to be to get the pulleys aligned. Believe the OPer stated he is aware it is mounted too far aft, but did it for additional fan clearance and he has not had a problem with belts being thrown off.
Old 03-16-2017, 12:40 PM   #19
toby
toby's Avatar
Thanks for all of your concerns. Please don't over-engineer this thing. It's working. I will take a look at it this spring (car is in storage) and see if it can be aligned better.
Toby
Old 03-16-2017, 02:24 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
Wow, I hate to bring this up, but...............the more I look at the angle of the top of the block's deck where it meets the head, and then compare that angle with the way the alternator is sitting, it looks like the nose (pulley) of the alternator is also twisted somewhat toward the right (passenger) side of the vehicle. Look closely and you'll realize that we're seeing this engine from a slight FRONT angle.....not straight-on from the side. DD
T5 W/TORQUE TUBE
