Old 03-08-2017, 09:37 AM   #1
GasWorksGarage
Default Steering column question
shouldn't the lower bearing housing be flush?
GasWorksGarage is offline   Reply With Quote
Old 03-08-2017, 09:53 AM   #2
GasWorksGarage
Default Re: Steering column question
http://www.snydersantiqueauto.com/Co...link--3688.pdf
also how does part 34Light rob felt seal go on? The seal I have only has like a .125" dia. hole in it?
Old 03-08-2017, 12:22 PM   #3
GasWorksGarage
ok So I got the column together and in I have not put the pitman arm on the sector shaft yet but I slide the steering wheel on and its very hard to turn. Any idea of what I have done wrong?
Old 03-08-2017, 12:31 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have the square brass shims in the end plate? You may have to add a few to give it more clearance. You want the clearance to just be at zero without binding the bearings.
Old 03-08-2017, 01:02 PM   #5
GasWorksGarage
yes I have 2 brass shims and a gasket
