Old 02-15-2017, 09:45 PM   #1
Smooth_One
Smooth_One's Avatar
Default Front Brake rod initial adjustment
I'm just finishing up the front brakes on my 28 and was just wondering where to set the clevis at the end of the brake rod to get a good starting point to begin adjusting the brakes?
I've replaced all the service brake and parking brake rods and anti rattlers as well.
So I guess my question is what is the correct length from brake rod eye to clevis eye or how much of the threads should be exposed at the end of the rod to get a good starting point?
And do I need shims with the operating pins if everything is new?
Thanks, Isaiah.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-15-2017, 10:16 PM   #2
160B
160B's Avatar
Default Re: Front Brake rod initial adjustment
Are you following the instructions in the Model A Ford Mechanics Handbook, by Les Andrews? If so follow the Service Brake Adjustment starting on page 2-1.
Here are some of the steps but I will not type all of them. If you do not have the Handbook I can post the 5 pages for you.
With the brake rods not connected to the front or rear actuating arms:
The Brake cross shaft should be in a vertical position.
Your front brake actuating arm should lean 15 degrees forward. Add pills to the wedge to position the actuating arm if necessary.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-15-2017, 11:12 PM   #3
CT Jack
CT Jack's Avatar
You haven't mentioned that you have the shoes on both wheels adjusted to the point where they are both slightly grabbing equally on both wheels. This is the very first step in the adjustment process. Once this is completed then you can follow the instructions in post #2
CT Jack is offline   Reply With Quote
Old 02-16-2017, 06:21 AM   #4
richsfords
richsfords's Avatar
length of rods, 50.5 inches center to center
Richard in New Bern.
When everything seems to be going against you, remember that the airplane takes off against the wind, not with it” - Henry Ford
richsfords is offline   Reply With Quote
Old 02-16-2017, 03:50 PM   #5
john in illinois
john in illinois's Avatar
This may be true for a brand new A,but for a used one I would follow #2.
Our club tried presetting rods with out much luck.
John
john in illinois is offline   Reply With Quote
