Old 02-08-2017, 06:13 AM   #1
aermotor
Default Head light adjusting screws
28 Tudor, During my shake down drives before I got my tires balanced (dyna - beads), which are great, I lost a headlight adjusting screw. Don't want to mess with my cork seals to see what size screw is used, so does anyone know what size the adjusting screw is?
John
aermotor is offline   Reply With Quote
Old 02-08-2017, 08:33 AM   #2
Paul Bennett
Default Re: Head light adjusting screws
If we're having a lottery I'll take 10-32 for $5
Paul Bennett is offline   Reply With Quote
Old 02-08-2017, 08:55 AM   #3
SeaSlugs
SeaSlugs's Avatar
i know its a fine thread and that sounds about right ^^^^^^^
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-08-2017, 10:42 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Parts Price List is one of the "must have" books for all Model A owners, and lists the 28-9 screw as:
A-20525-S13R in my July 1, 1931 edition. This is listed as 3/16-32 X 1 oval head special screw.
You might need to take the lamp apart anyway to make sure the spring is in place.
Special screw means you might have to call Bert's for the right screw. 800-321-1931
Old 02-08-2017, 10:51 AM   #5
aermotor
Thanks guys. Now what are the odds that the spring is still in place?
John
Old 02-09-2017, 12:35 AM   #6
Doug Clayton
It was listed as a special head screw because it is a 10-32 with a #8 head.
Doug Clayton is offline   Reply With Quote
Old 02-09-2017, 05:16 AM   #7
Bruce of MN
Bruce of MN's Avatar
Mine have unscrewed themselves, even after I used some dished star lockwashers. I have thought of adjusting the focus, counting the turns to unscrew, then putting them back in with some blue loctite on them. Or is there a better way to do it? The motor doesn't vibrate badly.
Bruce of MN is offline   Reply With Quote
Old 02-09-2017, 11:58 AM   #8
Bob C
I came up with the same a Doug, 10-32 x 1 1/8" special oval head 350120-S13.
Bob
Bob C is online now   Reply With Quote
Old 02-09-2017, 12:21 PM   #9
Special Coupe Frank
Special Coupe Frank's Avatar
Be careful the replacement screw is not too long - if it is, it can contact the hot terminals at the back of the socket and cause a short to ground.
I had to shorten the screws in the SS repro lights that came with my '28.
Special Coupe Frank is offline   Reply With Quote
Old 02-09-2017, 07:04 PM   #10
Jim/GA
Jim/GA's Avatar
What year is your car, Bruce?
Jim Cannon
Former MAFCA Technical Director
"Spread the Joy! Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 02-09-2017, 07:16 PM   #11
figment
I believe the screws are special and are threaded only part way and can only be screwed in so far. This is what I found on some original unmolsted headlamps. I have been looking for some originals that could be used for fine point. Good original ones are not easy to find. I also think 28-29 are different than 30-31 but I could be wrong.
figment is offline   Reply With Quote
Old 02-10-2017, 03:55 PM   #12
Bruce of MN
It is a '31.
Old 02-11-2017, 03:28 AM   #13
midgetracer
midgetracer's Avatar
30-31s are shorter, but thread size is the same.
midgetracer is offline   Reply With Quote
