Old 01-11-2017, 03:34 PM   #1
hotrodA
hotrodA's Avatar
Default 32 door handle D-nuts????
One of the doors on my 32 Tudor is missing the two D-nuts that the outside handle attaching screws thread in to. As they are almost impossible to access, does anyone have a suggestion on securing them? There is NO room to get anything in that spot. Thanks!
hotrodA is offline   Reply With Quote
Old 01-11-2017, 03:44 PM   #2
BillM
BillM's Avatar
Default Re: 32 door handle D-nuts????
Maybe a rivnut.
https://www.google.com/#q=rivnut
My web page:
http://myplace.frontier.com/~wgmumaw/
BillM is offline   Reply With Quote
Old 01-11-2017, 05:07 PM   #3
DavidG
DavidG's Avatar
There are high strength glues and epoxies that would do the job. GM is gluing the beds of its pickups to the chassis frame, at least in part.
Old 01-11-2017, 06:40 PM   #4
hotrodA
hotrodA's Avatar
Can't get in with anything like a rivnut tool. Thanks, tho.
Epoxy is a good idea. Need to figure out a way to scoot it in place and hold it. Paint stick?
Old 01-11-2017, 06:46 PM   #5
Karl Wescott
Karl Wescott's Avatar
slip the nut over a thin wire with a hook on the end that will not let the nut fall off. Thread the wire through the handle hole and back out the screw hole. Pull tight.
Karl Wescott is offline   Reply With Quote
Old 01-12-2017, 10:41 PM   #6
hotrodA
hotrodA's Avatar
Bingo!!
Thanks, Karl!
Old 01-13-2017, 01:01 AM   #7
Vics Stuff
Vics Stuff's Avatar
I would use the wire trick as Carl mentioned . Has worked for me in the past. I would use the 24 hour full cure JB weld to glue the D nut on the back side. When done you will probably need to chase the threads with a tap.
Vic
Vics Stuff is offline   Reply With Quote
Old 01-13-2017, 10:44 AM   #8
hotrodA
hotrodA's Avatar
Sounds like a plan! Thanks to all of you.
