01-09-2017, 01:11 PM | #1 |
Computer question...
After installing "page numbers" within a document...what, then is the correct procedure to "remove" the page numbers from that same document?
Thanks. Pluck |
01-09-2017, 01:13 PM | #2 |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Re: Computer question...
Did you create the document or did you copy an existing document?
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
01-09-2017, 01:17 PM | #3 |
is this in Word? - if it is check under INSERT then should be a box labeled Header&footer check the page number thing under there.
If its older versions of word i think its under page setup or layout but should be under header and footer area regardless.
1929 Model AA - Need long splash aprons! |
01-09-2017, 01:22 PM | #4 |
If it's in Word, bring the document up and delete the numbers and when he goes to 'save' the document, he'll be asked if he wants to save the changes, yes, and the changes are gone.
01-09-2017, 04:37 PM | #5 |
The most intuitive way to do this in WORD would be to put your cursor next to the page number in the footer of your document. Any page will do. Now double click to put you in editing mode for the footer. Delete the page number as you would for text in the main body of the document. This will delete the page numbers for all pages EXCEPT if you have set up your document in sections, in which case you'll have to repeat this process for each section.
01-09-2017, 04:48 PM | #6 | |
01-09-2017, 09:30 PM | #7 |
Assuming you are using MS Word, it depends on the version that you are using. In most versions it is in the Header/Footer which is accessed by going to View>Header. If you are using a version that uses 'the ribbon' controls, you go to the Insert ribbon and then Page Number on the Header & Footer section.
Style beats speed any day, and with a lot fewer tickets. |
01-09-2017, 09:57 PM | #8 |
Get some "White Out" from the local office products store.
Fred Kroon 1929 Std Coupe 1929 Huckster |
01-09-2017, 11:38 PM | #9 |
Thanks guys.
Pluck |
01-09-2017, 11:39 PM | #10 | |
Microsoft Office Word 2003 Pluck |
01-09-2017, 11:46 PM | #11 |
Forgot to say that Post #5 specifically referred to WORD 2010.
01-10-2017, 12:08 AM | #12 |
so I take it you got it figured out
01-10-2017, 10:32 AM | #13 |
Funny this non-topic post has yet to get deleted... I wonder why some do and others don't. Anyone know why?
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
01-10-2017, 11:04 AM | #14 | |
Depends on the thread poster and who does the complaining....IMO!!!
01-10-2017, 11:44 AM | #15 |
01-10-2017, 12:03 PM | #16 |
I agree Tom 100%, without a computer, we wouldn't/couldn't be here. I'm not a computer geek, self taught what I know and I forget easy what I have learned.
01-10-2017, 12:05 PM | #17 | |
Things like the new f-150 aluminum alloy body Or Joe Blow driving his Citroen down the road backwards for 3.8 miles ... I applaud Ryan for the job he does,,, it cant be easy JMO ""Thanks Pluck"" Last edited by Mitch//pa; 01-10-2017 at 12:14 PM. |
01-10-2017, 05:37 PM | #18 |
I'm all fine with ANYONE asking ANY question.... However for me posting about a seatbelt recall, I was given 1 week of timeout (disabled)... So I don't post as often... So as mentioned above by Ed, all depends who is it, not what is posted.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio Last edited by mshmodela; 01-11-2017 at 06:36 AM. |
01-10-2017, 06:02 PM | #19 |
I'm surprised that no one has mentioned that Henry would have used an eraser.
01-11-2017, 12:07 AM | #20 |
a natural rubber eraser for those fine point erasings
