Old 11-20-2010, 05:45 PM   #1
Nelson
Default Late 1931 Model A Gas Tank
Can a late 1931 style gas tank be installed in a 1930-31 car with
a straight firewall (not indented firewall) without damaging or
affecting the straight firewall?
Does the late 1931 tank outlet align up with the hole in the
straight firewall used by the fuel bowl?
Thank you.
Nelson is offline   Reply With Quote
Old 11-20-2010, 06:07 PM   #2
Joop
Joop's Avatar
Default Re: Late 1931 Model A Gas Tank
Page 561 Model A Service Bulletins
All about new (late cowl tank) and holes do not line up.
Joop is offline   Reply With Quote
Old 11-21-2010, 05:35 PM   #3
Nelson
Joop,
Thank you for the excellent response. I looked at the Service Bulletin.
Not wanting to put a 1 & 3/4'' hole in the firewall. Would you think that it's possible to make-up some kind of connection to fit from the late '31 tank outlet that would curve and go through the existing hole in the straight firewall (1 & 5/8" away where the glass fuel bowl mounted)?
I realize that it wouldn't be original, but would a rubber type of gas hose work or something else?
Thanks for the reply.
Old 11-21-2010, 06:36 PM   #4
peters180a/170b
peters180a/170b's Avatar
Why ?? are you in need of a gas tank ? and you only have a late 31? if we knew what state you are in at least then someone might have a tank for ya to swap.
peters180a/170b is offline   Reply With Quote
Old 11-23-2010, 11:09 PM   #5
Bill Stipe
Bill Stipe's Avatar
Pete I am having the same trouble too I need a 31 gas tank with round speedo for a straight fire wall and I have a late 31 tank for an indented firewall.
Bill Stipe
Plymouth Wisconsin
Building Horse Power --
Bill Stipe is offline   Reply With Quote
Old 11-24-2010, 06:48 AM   #6
peters180a/170b
Call Doug Bruce , he might be able to help ,he has a few really good ones. 1-607-849-3454 N.Y.
