Old 11-14-2016, 03:37 PM   #1
GasWorksGarage
Default Model A starter
So does anyone have a diagram for inside the contact box on a model A starter?
GasWorksGarage is offline   Reply With Quote
Old 11-14-2016, 04:11 PM   #2
Bob C
Default Re: Model A starter
Are you asking about the starter switch?
Bob
Old 11-15-2016, 08:49 AM   #3
GasWorksGarage
Bob
yes that sits on top of the starter
Old 11-15-2016, 10:31 AM   #4
tbirdtbird
Inside, a moveable contact makes connection with a copper button in the starter case when you step on the starter pedal. The copper button is wired to the field windings. The moveable contact is spring loaded so that when you release the pedal, the contact springs open, and the starter stops spinning
Thus electricity from the battery can be connected and un-connected to the starter windings. Quite simple actually. Was the standard method for a long long time for nearly all makes of vintage cars
'31 180A
tbirdtbird is offline   Reply With Quote
Old 11-15-2016, 10:41 AM   #5
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Take it apart and you will find that it is very simple. The only critical part is the isolation of the hot circuit. Big current here. You don't want any shorts to ground. Could ruin your whole day.
Jacksonlll is offline   Reply With Quote
Old 11-15-2016, 10:47 AM   #6
C26Pinelake
take it off and turn it upside down and you will see how basic it is. Wayne
C26Pinelake is offline   Reply With Quote
Old 11-15-2016, 10:48 AM   #7
GasWorksGarage
Well I took mine apart because it stopped working. I took sand paper and cleaned the contacts. while doing this a cross shaped piece fell out I put it in where I thought it goes but apparently I am wrong. That is why I was wanting an exploded view.
Old 11-15-2016, 10:48 AM   #8
JBill
Also note the insulating gasket between the starter and the switch body.
JBill is offline   Reply With Quote
Old 11-15-2016, 10:49 AM   #9
SeaSlugs
SeaSlugs's Avatar
Cross shaped piece? I dont remember there ever being a cross shaped piece in a stock switch...
Speaking of amps does anyone know what a Model A starter draws amp wise on a stock system?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-15-2016, 11:15 AM   #10
Cape Codder
Cape Codder's Avatar
Don't know if I would call it a cross shaped piece, but isn't there a small part that goes in the bottom of the rod which in turn pushes onto the spring loaded brass contact piece?
Cape Codder is offline   Reply With Quote
Old 11-15-2016, 11:20 AM   #11
5lugnuts
The cross looking piece might be a piece of dried leather that goes in the end of the push rod. It pushes against the bronze flat piece (spring) that makes contact between the battery and the starter. High amp negative battery cable. I had to replace mine because of deterioration. I used the shaft of a nylon bolt with the head cut off if memory is correct.
5lugnuts is offline   Reply With Quote
Old 11-15-2016, 11:26 AM   #12
700rpm
700rpm's Avatar
Cape Codder is closest to the right answer. It is part of the activation/push rod setup, but I don't know how to explain it, and I don't have a photo or diagram. All I can say is, don't toss it. It's part of the switch.
Ray Horton, Portland, OR
Old 11-15-2016, 11:32 AM   #13
Bob C
This link shows a breakdown of the starter and switch.
http://www.snydersantiqueauto.com/Co...Motor-7019.pdf
Bob
Old 11-15-2016, 11:36 AM   #14
H. L. Chauvin
Maybe ............ your Model A & starter switch came from a Monastery ..... hence, the "Cross."
But on a more serious note, a descriptive attempt to echo the above may or may not assist:
Some starter switches had an internal non-conductive fiber "T" where the "longer" vertical part of the "T" was inserted upwards into the lower end of the metal cylindrical tube like starter switch plunger.
(The other upper end of this switch's plunger is threaded to receive the threaded starter rod.)
The lower horizontal part of this fiber "T" contacted the starter switch's non-ferrous movable blade down below.
Because the starter switch plunger is grounded, this "T" insulates the cylindrical metal plunger when it contacts the "hot" blade below.
Then when the starter switch plunger is depressed, it pushes the "hot" blade downward to contact the button on top of the starter which electrically energized the starter.
Some new starter switches have white "Delrin" plastic "T's" in lieu of fiber "T's".
Other than that, if incorrectly described, you may need to "Cross-Reference" your cross with all of the above .... or call your local Monastery.
H. L. Chauvin is offline   Reply With Quote
Old 11-15-2016, 11:42 AM   #15
GasWorksGarage
here is a picture of the " cross" piece, also there wasn't a gasket so I will make one.
Old 11-15-2016, 11:46 AM   #16
GasWorksGarage
I got it thanks for the link Bob, and thanks to all for the help!
Old 11-15-2016, 11:54 AM   #17
Y-Blockhead
Y-Blockhead's Avatar
Your "T" (Plunger Button, part #35 in Snyder's drawing) isolates the plunger from the Starter Switch Contractor (part #31).
Old 11-15-2016, 12:02 PM   #18
H. L. Chauvin
And in general, FWIW:
The new starter switches offered today usually need some metal shaping work around the hole that receives plunger to make them operate correctly.
Main problem is, because of an incorrectly manufactured plunger angle, the plunger hangs up & remains "depressed"; hence, after the engine starts, the starter continues to rotate.
Not too difficult to fix with a little patience and a round file; however, many times it was also recommended herein to try to obtain original starter switches to avoid this very costly starter problem.
Old 11-15-2016, 12:44 PM   #19
100IH
All correct, except the switch to starter body is not for electrical insulation. The 4 screws holding the switch on ground the switch cover to the chassis ground; the starter itself.
100IH is offline   Reply With Quote
Old 11-15-2016, 01:35 PM   #20
midgetracer
midgetracer's Avatar
The gasket between the starter switch and the starter was only used on the early cars. None is needed on the later A's. I am not sure of the exact date when it was dropped, but if yours does not have one, it is probably not needed.
midgetracer is offline   Reply With Quote
