Old 10-19-2016, 07:16 AM   #1
callbald
callbald's Avatar
Default lubing closed driveshaft 39 pickup
What is the proper way to lube the driveshaft ujoint at the transmission. Here I was told to pack it with grease. Just did a rebuild on the engine and transmission and don't want to screw this part up. Thanks
callbald is offline   Reply With Quote
Old 10-19-2016, 08:09 AM   #2
Kube
Kube's Avatar
Default Re: lubing closed driveshaft 39 pickup
I'd suggest you pack it with John Deere Cornhead grease. That's available at all dealers.
Old 10-19-2016, 04:56 PM   #3
callbald
callbald's Avatar
thanks, just bought it. Was hard to find
Old 10-19-2016, 07:20 PM   #4
Talkwrench
Talkwrench's Avatar
No need to go overboard with it, your trans oil will work its way in there soon enough.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-20-2016, 10:16 AM   #5
G.M.
Don't forget the grease fitting in the center of
the drive shaft. G.M.
www.fordcollector.com
Old 10-20-2016, 11:30 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
What Kube said. I've been doing mine like that for ~ 5 years now. I also shoot some in at speedo gear before I bolt the turtle on. And shoot a little in at the zerk on the clam shell halves.
John
