Old 08-15-2016, 12:11 AM   #1
John Spragg
Default Front Crank Seal Direction
I am a bit confused here I have purchased from Snyder's a front crank seal- now which way does it go on? - could some one please give me a good description on this or a diagram or hand drawing or something to eliminate any doubt, I have had varied pieces of advice and thus the confusion. Thanks I sound like a real dummy I know, however I just do not know. John Spragg Australia. ]Hope you can help.
John Spragg is offline   Reply With Quote
Old 08-15-2016, 12:55 AM   #2
700rpm
700rpm's Avatar
Default Re: Front Crank Seal Direction
The rounded edge goes to the outside. The flat edge goes to the crank. Soak it in oil for a few hours before you install it. I use a socket on its side and lightly tap the seal into place. When you install the crank and pan it will pull together.
Ray Horton, Portland, OR
Old 08-15-2016, 02:11 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Are you talking a rope seal, as original?
Or, did you buy the one piece seal?
I like the original rope seal, but if you have the one piece, the open side faces the rear of the engine. Be sure to smear grease on the lip of the seal. The seal also needs to be locked in place with silicone, as I understand it, so that must be done just as the oil pan is ready to be bolted in place.
If it's a rope seal, I never soak them in oil, but squirt oil on after it's installed in the slot, and I also smear grease on the rubbing surface.
Old 08-15-2016, 02:17 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
"A-6700-M FRONT CRANK SEAL
No modifications to engine required.
Replaces B-6700-A packings.
Fits 1928-34 4 cyl. and 1932-53 V8 engines.
Install with lip towards rear of engine. Rubbing surface must be
smooth and not worn. Original shaft diameter is 1.625 inches.
Deburr crank pulley before assembly. Bed the OD of the seal in
silicone gasket sealant."
Notice where it says, "Rubbing surface must be smooth and not worn" They really mean mirror finished and tracks absolutely true. Anything but dead smooth and any "wobble" and the seal will fail to keep the oil in the engine.
Don't just take my word for it, do a search for "modern seal" here on the barn.
Old 08-15-2016, 02:27 AM   #5
700rpm
700rpm's Avatar
Right. I always assume guys are building stock. Not always true.
Old 08-15-2016, 06:44 AM   #6
George Miller
George Miller's Avatar
I do like Tom and after 60 years and many seals and many different kinds of cars (knock on wood) no leaks. I would not use the one pice seal.
George Miller is offline   Reply With Quote
Old 08-15-2016, 12:51 PM   #7
hardtimes
hardtimes's Avatar
Hey John,
What type seal , i.e.- rope, cork, modern, are you installing/asking about
FWIW, I've currently installed two modern front seals, and in past other types...no leaks.
hardtimes is offline   Reply With Quote
Old 08-15-2016, 05:24 PM   #8
John Spragg
This is a modern seal - round one - John Spragg
Old 08-15-2016, 05:54 PM   #9
Mitch//pa
Mike answered your question above... The installation instructions are taken directly from snyders site
