Old 08-03-2016, 10:06 PM   #1
fresnoron
Default 37 rod bearings
the new rod bearings for my 37 are flanged. Do these still need to be fitted using the hammer method?
fresnoron is offline   Reply With Quote
Old 08-03-2016, 10:47 PM   #2
Brian
Brian's Avatar
Default Re: 37 rod bearings
yes
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 08-04-2016, 01:08 AM   #3
cretin
cretin's Avatar
Yea, I asked about that on my '37 rebuild thread. Same procedure, just takes longer because you have to keep removing and replacing the rod cap to check the fit. I just went through it on Monday.
cretin is offline   Reply With Quote
Old 08-04-2016, 03:57 AM   #4
scooder
I hope the old bearings are flanged aswell!
Martin.
scooder is offline   Reply With Quote
Old 08-04-2016, 07:08 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Ol Ron covers how he does bearing fitting in his book "Nostalgia". Probably covered in other Flathead publications as well.
John
Old 08-04-2016, 08:50 AM   #6
Ol' Ron
Ol' Ron's Avatar
Martin has it.37 was a mixed year where Ford went from flanged to non-flanged bearings. I always have the rods honed for .001-.0015 oversize. More for racing.
Ron Horrell is replacing the 296 I built for him back in the late 90's (over 50K on it now) with his new Blown engine. It was built the old way, stroked Merc crank and 21A rods. I'll be curious to see how they held up.
Old 08-04-2016, 12:43 PM   #7
fresnoron
Thanks all...yes they are flanged on my engine
Old 08-04-2016, 01:29 PM   #8
fresnoron
so do they have to float both over the crank journal AND inside the rod at the same time or just either one freely.
Old 08-04-2016, 07:56 PM   #9
Barn Junk
Barn Junk's Avatar
The goal is to allow an even coat of oil to flow through all bearing surfaces to lubricate and cool.
Barn Junk is offline   Reply With Quote
Old 08-04-2016, 08:06 PM   #10
v8fordman
v8fordman's Avatar
Regarding post #6. I have never seen an original '37 engine that did not have flanged rod bearings. I don't think there were any non-flanged bearings.
v8fordman is offline   Reply With Quote
Old 08-04-2016, 09:16 PM   #11
Ol' Ron
Ol' Ron's Avatar
V8fornman. You maybe right, as I haven't worked on many 37's. I think the flanged bearing went out in 38, but it's been so long. I cut the flanges off and use the bearings on the stroker cranks.
