Old 08-03-2016, 08:14 PM   #1
david.skinner
david.skinner's Avatar
Default Spark plug caps
I noticed today that one of my plug caps didn't seem to be well connected to the plug so I pulled it of and it was internally broken so now I'm concerned about the others.
Do the replacement caps need internal resistance? The setup is an 81A with a crab distributor, 12v -ve earth and Skip 12v coil with multistrand ignition cable. I know that its is likely covered elsewhere but I was unable to find it.
Thanks.
David
david.skinner is offline   Reply With Quote
Old 08-03-2016, 08:41 PM   #2
JSeery
JSeery's Avatar
Default Re: Spark plug caps
Assume were talking spark plug wires here. Unless you are concerned about radio interference you do not need resistance wires or any other type of resistance in the high energy circuit. If you are just referring to the end that connects to the plugs (the boot) there are clips that were popular in the early years (if you are not attempting to remain original). The type I like are the Rajah Clips (with solid core Packard 440 type wiring).
The Hot Rod Company has several options for plug wires and ends: http://www.thehotrodcompany.com/shop...y=bsp&first=20
Old 08-03-2016, 10:59 PM   #3
david.skinner
Thanks so much for this Jseery
Old 08-04-2016, 06:23 AM   #4
Steves46
Steves46's Avatar
I have been using these for years-they work great and look really cool!
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 08-04-2016, 04:04 PM   #5
david.skinner
Thank you all for your help - now ordered.
Regards
David
