#1 |
So if I'm driving up a long incline ( Bourne Bridge ) in second gear the Trany will disengage into neutral. Big problem ? Thanks
#2 |
That's been a popular topic here, use the search tab and let er rip. Could be big could be little.
#3 |
Before pulling the trans check for wear in the shift tower - worn forks, plungers, shift rails etc. can cause trans to walk out of gear. It's much simpler to inspect and repair the tower if necessary than to pull engine and trans or rear end and trans.
I Love Anything That Turns Money Into Noise |
#4 |
let us know how you make out
'31 180A Last edited by tbirdtbird; 02-03-2017 at 12:23 AM. |
#5 |
If it is not the tower, rebuild the trans with all new gears, shafts etc. etc.
mike |
#6 |
Bob |
#7 |
yes; some stretch the spring but i didn't want to set up a stress riser
'31 180A |
#8 |
My experience with 2nd gear issues is that it is usually the gear. In my case worn to a "taper" on the teeth which makes it wont to "walk" off the cluster gear.
May be fixable without removing the transmission by removing the rear shaft/bearing retainer. Although by the time you walk back the rear axle at the universal joint, you might as well take the next step. Joe K
Shudda kept the horse. |
#9 |
Yikes" well I'll inspect her. I'll get back and let you know what I find. Thanks very much
#10 |
Rather than the Bourne bridge, try the Sagamore.
Marc |
#11 |
How about the tunnel? Much more direct and only the locals know about it.
#12 | |
![]() Quote:
Joe K
#13 | |
![]() Quote:
#14 |
Swap out the top first if it is still doing it you will need to pull and rebuild the transmission
