Old 07-26-2016, 10:59 AM   #1
William Kelchner
William Kelchner's Avatar
Default Xmission Oil
How much 600wt gear oil does the transmission hold. Want to change mine as I have no clue how long it has been in there, at least 11 years. Looks like a messy job. TIA
Bill Kelchner
William Kelchner is offline   Reply With Quote
Old 07-26-2016, 11:56 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Xmission Oil
Warm the tranny up with a good drive, then pull the drain plug and let it drain over night. One quart should be enough, but just keep filling until it's ready to flow out the fill plug.
Buy extra oil so you can refill as needed.
Old 07-26-2016, 12:03 PM   #3
William Kelchner
Thanks Tom.
Old 07-26-2016, 01:36 PM   #4
C26Pinelake
Great advice on all three counts! Wayne
C26Pinelake is offline   Reply With Quote
Old 07-26-2016, 01:44 PM   #5
William Kelchner
Looks like I'm going to have to order this oil as there is none in the village of Warrenton Va.
Old 07-26-2016, 03:27 PM   #6
Keith True
Keith True's Avatar
Remember,it is 600W oil,not 600 weight.That was a designation that somehow got morphed into WT over the years.If you try to research the specs for 600W in that time period you will find the viscosity was between 140-240.A few years ago I drained all my cars out over the winter,in the spring I filled them all with 90WT.It was what I had a drum of in my garage.I figured it would wash out any of the old tallow stuff left,then I could put in something else.I never bothered,it is still in there.
Keith True is offline   Reply With Quote
Old 07-26-2016, 04:16 PM   #7
William Kelchner
Thanks Keith I was not aware of that.
Old 07-26-2016, 05:07 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You could try 140 weight, with a little thickener addititive if needed. Sorry can't think of the name at this moment.
Old 07-26-2016, 05:13 PM   #9
daveymc29
daveymc29's Avatar
Stp?
daveymc29 is offline   Reply With Quote
Old 07-26-2016, 05:26 PM   #10
eagle
eagle's Avatar
Put in Lucas Oil Stabilizer. It works great.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 07-26-2016, 05:45 PM   #11
Nabco
Nabco's Avatar
I'm using Lucas Oil Stabilizer in mine now and she never shifted better.
1930 Deluxe Coupe
"Sister"
Nabco is offline   Reply With Quote
Old 07-27-2016, 10:37 AM   #12
jheinrichs
Is it better to use 100% Lucas Oil Stabilizer or a mixture of Lucas and 600W? If mixed, what ratio? Still having trouble down shifting.
jheinrichs is offline   Reply With Quote
Old 07-27-2016, 11:32 AM   #13
William Kelchner
hey thanks for the info looks like Lucas Oil Stabilizer it is. If it is suitable for the xmssion I presume it can be used in the rear and steering box?
Old 07-27-2016, 11:42 AM   #14
Joe K
Joe K's Avatar
Originally Posted by daveymc29 View Post
Stp?
Ha, ha. YOU KNOW full well that STP is NOT AN OIL.
Trolling its called.
Joe K
STP 100 percent and still going strong.
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 07-27-2016, 12:44 PM   #15
Patrick L.
Patrick L.'s Avatar
Let us know how it works out. We'll [ I'll ] be interested. It foamed so bad it made mine unshiftable.
Old 07-27-2016, 12:47 PM   #16
Patrick L.
Patrick L.'s Avatar
What oil are you using now ?
How long have you been trying to figure this shifting thing out ? It takes time.
Just a suggestion, try raising the engine speed even more and see that helps.
Old 07-27-2016, 12:49 PM   #17
Brian T
Brian T's Avatar
Can someone tell me about Lucas oil stabilizer, is it the same consistency as STP.?, ---- I am interested if anyone recommends a anti foam additive for the transmission oil.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 07-27-2016, 01:49 PM   #18
Nabco
Nabco's Avatar
I'm using Lucas Oil Stabilizer in both the trany and steering box, have not seen any foaming....
1930 Deluxe Coupe
"Sister"
Old 07-27-2016, 08:24 PM   #19
eagle
eagle's Avatar
The Lucas HUB oil foams, I have had NO issues with the oil stabilizer foaming. Works well in differential too. Maybe reacting to whatever you had in transmission before????
Old 07-28-2016, 12:14 PM   #20
William Kelchner
Smile Re: Xmission Oil
Well now that the car is running somewhat decent I crawled under to drain the transmission. Stuck a finger in the fill hole and it came out bone dry. Took out the drain plug and got all of 1/2 cup of black something........I double clutch and never had any problem shifting,or grinding but the car had what I thought sounded like gear whine. My friend up the road Quigely provided me with some 600W gear oil. I'll let this thing drain (drip) overnight per Tom W. suggestion, get some oil in there and go for a spin tomorrow. Cheers
