Old 06-26-2016, 10:00 AM   #1
Bren B
Default Canadian 1933 three window value
I'm going to look at a 1933 three window for sale that is a Canadian built car. It has been converted to hydraulic brakes, the battery has been moved to under the hood, it is also painted two tone red body and black fenders with a cream colored dash. Otherwise the car is seemingly restored all original and supposedly no rust, good running and driving. My question is mainly how does it being a Canadian built car affect its value to a U.S. Buyer? Or is the rarity of a mostly unmolested three window coupe not affected by where it's built?
Bren B is offline   Reply With Quote
Old 06-26-2016, 10:49 AM   #2
34pickup
34pickup's Avatar
Default Re: Canadian 1933 three window value
Just my personal opinion but those are considered so desirable that I don't think where its built would matter. Which arm and leg are you prepared to give for it? ☺☺
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 06-26-2016, 11:43 AM   #3
DavidG
DavidG's Avatar
The original difference between the two are in details, most of which are minor. If the original top material and upholstery material are long gone, which likely is the case given that it was restored, the most prominent remaining difference would be the absence of a U.S. patent plate on the firewall (unless it was restored with "Made in Canada" Champion spark plugs and script battery case.
If all was fair the world, it actually should be worth more than one built in the U.S. if one was striving for uniqueness of originality as body-colored fenders, etc. were an extra cost option on Canadian '33s whereas that paint treatment option was not available on the U.S.-built versions.
Old 06-26-2016, 12:00 PM   #4
TJ
TJ's Avatar
If the battery is under the hood and they hacked up the firewall to make the installation, it definitely devalues the car. It would be costly to put it back to original. That alone would be an indication to check closely for other questionable work done to the car.
Old 06-26-2016, 12:13 PM   #5
Barlea
My '33 two door had all the steering box holes in the frame that would be needed for export to right hand drive countries. Dad bought it in '41, I got it in '55 when I was 13. ..B.
Barlea is offline   Reply With Quote
Old 06-26-2016, 12:49 PM   #6
cas3
this has been up before, https://www.fordbarn.com/forum/showthread.php?t=189864 the fact that is canadian would make no difference at all due to the high demand and low number available. not so perfect bare body sold for 36k last week at ebay so dont tell any one where it is!
cas3 is online now   Reply With Quote
Old 06-26-2016, 07:41 PM   #7
Bren B
Thanks for the replies. I was fairly certain that it did not significantly impact the value negatively. I am however, not a very educated buyer and wanted to know about the canadian built cars. I know that each cars value is basically what a buyer and seller agree upon and the best you can do is sit back and watch the general trend.
