Old 06-22-2016, 10:12 AM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default Lincoln Zephyr distributor dual coil
I got this Lincoln Zephyr distributor in a bunch of parts I recently purchased. The writing on the masking tape indicates Lincoln Zephyr V8 converted. Can anyone explain how this was done and why it would be of any advantage. Only thing I can foresee is a hotter spark with the dual coils.
Thanks guys,
Seth
Seth Swoboda is offline   Reply With Quote
Old 06-22-2016, 10:27 AM   #2
SUHRsc
SUHRsc's Avatar
Default Re: Lincoln Zephyr distributor dual coil
The use on a V8 allows it to work as though it is 2 seperate 4 cylinder ignitions. Each firing half of the cylinders. This in turn gives twice as much time for coil saturation. Which then means you can get more RPM's without loss of good spark.
If you want to part with it, I may be interested as I am trying to build one right now for my own car.
Zach
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 06-22-2016, 10:51 AM   #3
topfuel724
topfuel724's Avatar
Car Craft had a 3 part article in the April, May and June 1954 issues on how to convert the Lincoln V-12 distributor for use on the flathead V-8.
topfuel724 is offline   Reply With Quote
Old 06-22-2016, 10:56 AM   #4
JWL
There is more than one way to make this work. I am familiar with changing the cam to 4 lobes, extending the reach of the cap terminals, changing the rotor and a few other things my 40 year old memory is not ready for. The advantage, as already mentioned, is increased spark coverage in the upper RPM range.
JWL is offline   Reply With Quote
Old 06-22-2016, 11:21 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Zach
Zach, I recently traded some parts + some cash to get one for the same thing.
A guy local to me has a complete Lincoln V12 distributor, already converted to the dual coil, dual point setup for the V8, that's for sale, but I'm thinking I would rather do my own for the learning experience.
Seth, you and your Dad are doing very good on buying cars and parts!! Glenn, Jeff and I should think about making a special trip to the St. Louis area just to get in on some of these great deals
John
Old 06-22-2016, 11:34 AM   #6
Seth Swoboda
Hey, I also got a genuine Offenhauser dual carb intake, wide spacing. It's the real deal not the new reproductions. I'd say we are pretty fortunate to be able to have the flathead vehicles and parts that we do. No doubt all of us here are blessed. What I really enjoy is all the friendship and knowledge that everyone is willing to share.
JM, you should have stopped in on the way back from Tulsa, I could have used help moving these parts. I know you were on a schedule. Perhaps another time. I'm located just off of interstate 64, 50 miles east of St. Louis.
Old 06-22-2016, 11:54 AM   #7
Bruce Lancaster
There are several schools of thought on all the mods...they were done commercially (as kits or as complete) by at least 2 major suppliers, and many individuals did their own conversions.
On the cap/rotor phasing...some added long strips curved around the rotor to the cap contacts, some slit the rotor contacts and put in long curved blades to reach the relevant terminals that way. Either allows adding material to close down gaps, important because new caps and rotors almost do not exist.
Most used 78 point plates (stripped and redrilled) with lawnmower/small plane points that are now very expensive. I have one that kept the double LZ plate, I think an excellent idea allowing points to be phased and timed separately rather than being totally dependent on the precise drilling for their screws.
I would try to figure out a way to do this and I would sure adapt some reasonably available automotive points! Probably '50's Ford or Mopar due to compact size...
(another school of thought...there were some based entirely on the 78 distributor...I've never actually handled one of these, but assume they stuffed in the LZ rotor as part of the process. They used an adapter plate up top to attach the LZ coil unit.)
Bruce Lancaster is offline   Reply With Quote
Old 06-22-2016, 11:59 AM   #8
Bruce Lancaster
And for those who aren't entirely mad, there are dual coil conversions (again, commercial and homemade) of the 59A distributor, cap, and rotor. This is by far the simplest DC conversion I know of, without all the fiddly mods of the LZ or the crazy stack of aftermarket plastic of the Harmon Collins.
Old 03-24-2017, 05:16 PM   #9
Jason in TX
Jason in TX's Avatar
Here are some pics of my 33-36 style distrib with Lincoln guts stuffed inside and an adapter on top for the dual LZ coil. I recently acquired a 33-36 V8 distributor that has the adapter and LZ coil.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 03-24-2017, 06:12 PM   #10
bruce lee
Jim kurtan was the first guy to do a LZ conversion. He then taught the Spaulding brothers everything they knew about ignitions. Jim worked on aircraft engines in the war time and figured out that aircraft can reach very high rpm. So he took apart an old airplane magneto. He use scintilla Magneto points and made about 60 distributors. By then other guys started to copy them so he didn't make any more. I have an original jim kurtan that will go into my 32 roadster. If you find one at a swap meet and it has scintilla points you hit the jack pot.
bruce lee is offline   Reply With Quote
Old 03-24-2017, 06:20 PM   #11
bruce lee
Here are some pictures
Old 03-24-2017, 06:21 PM   #12
bruce lee
Here are the scintilla points
Old 03-24-2017, 06:22 PM   #13
bruce lee
Maybe here are the points sorry I can't figure out this site on posting pictures.
Old 03-25-2017, 01:35 PM   #14
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Those a Bendix magneto points available today new ( about 50 per set) from some of the old aircraft suppliers.....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-25-2017, 02:02 PM   #15
bruce lee
Awesome bubba I need a few sets for some of my set ups. Can we get them through you???
Old 03-25-2017, 04:12 PM   #16
supereal
supereal's Avatar
Skip Haney rebuilds the Lincoln coils. (941) 505-9085. Good guy, good work.
supereal is offline   Reply With Quote
Old 10-29-2017, 12:23 PM   #17
NealinCA
NealinCA's Avatar
I picked this conversion up recently. Any info on it would be appreciated.
Thanks,
Neal
NealinCA is offline   Reply With Quote
Old 10-31-2017, 11:31 AM   #18
Jason in TX
I just saw this. Apparently you could also just buy a kit!
File Type: jpg 22852933_10213129058173127_5027797961010791715_n.jpg (28.8 KB, 450 views)
Old 10-31-2017, 11:35 AM   #19
Jason in TX
April 1954 Car Craft Moon Tech Article (part 1 of 3)
Old 10-31-2017, 11:39 AM   #20
Jason in TX
May 1954 Car Craft Moon Tech Article (part 2 of 3))
