Old 06-20-2016, 11:23 AM   #1
J Witt
J Witt's Avatar
Default '36 Transmission cover question
My transmission cover has what appears to be a louver stamped into it (center of photo) that has been bent at some point. It seems to me to be a strange place for a louver, so thought I'd see if anyone recognizes this and can tell me what it's shape should be. This one is bent to the point where it's hard to tell whats going on.
Thanks,
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 06-20-2016, 11:36 AM   #2
iverson
iverson's Avatar
Default Re: '36 Transmission cover question
thats how you read the vin no. its stamped on trans case
iverson is offline   Reply With Quote
Old 06-20-2016, 11:44 AM   #3
J Witt
J Witt's Avatar
So it should normally be matching the contour of the rest of the part? I'm going to flatten it back out before having the parts coated.
Thank you
Old 06-20-2016, 12:17 PM   #4
Marvin/TN
Send a message via AIM to Marvin/TN
I have one of those covers around somewhere but I don't think it's supposed to be flattened but raise up like the one shown.
Marvin/TN is offline   Reply With Quote
Old 06-20-2016, 12:49 PM   #5
rotorwrench
rotorwrench's Avatar
I don't know much about the 36 but it looks like a knock out plug to me. I figure you could level it back down if you want to. As long as your car is registered and you already know the VIN, you don't need to see the number that much. Heat always finds its way into the cab on the old Fords. I don't think I'd want to help it out much but then I live in the south Texas hot country.
Old 06-20-2016, 12:57 PM   #6
Charlie Stephens
Most DMV's don't know or care about the number on the transmission. They go by the number on the frame.
Charlie Stephens
Old 06-20-2016, 01:33 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Push it back down level with the contour of the surrounding sheet metal. Put some tape over top to seal it up, and cover with your floor mat.
John
Old 06-20-2016, 01:35 PM   #8
DavidG
DavidG's Avatar
On the several covers that I have it is straight and only open about an 1/8". It would have to be pried up in order to see anything below it. Yours looks like that's what happened to it.
Old 06-23-2016, 10:54 AM   #9
J Witt
J Witt's Avatar
Thanks for all the good info, I knew that someone would have a handle on that. There was a nice surprise waiting under there: the transmission number and frame numbers match. Cool.
John
