Old 06-13-2016, 08:03 PM   #1
Traintyre
Send a message via Yahoo to Traintyre
Thumbs down 1932 Fuel Tank on Model A
How do I install a NEW 1932 fuel tank on a Model A Pickup?
Traintyre is offline   Reply With Quote
Old 06-13-2016, 08:36 PM   #2
700rpm
700rpm's Avatar
Default Re: 1932 Fuel Tank on Model A
Why do you want to do that?
Ray Horton, Portland, OR
Old 06-13-2016, 10:55 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Is is a car or pickup tank?
I think the pickup tank was under the bed in the '32 but since the A never came with a rear tank, any way you can mount it would be correct.
Old 06-14-2016, 09:07 AM   #4
tim54889
It goes under the seat on a 32 pickup, then you will need a fuel pump.
tim54889 is offline   Reply With Quote
Old 06-14-2016, 09:30 AM   #5
Jim Brierley
Before you install a passenger '32 tank on a pickup check that you will have access to the fill neck.
Jim Brierley is offline   Reply With Quote
Old 06-14-2016, 11:18 AM   #6
Charlie Stephens
Why do you want to move it? I think if I relocated it I would add saddle tanks between the frame and running board apron (available as a kit). Someone makes a kit to do what you are trying to do on Model A passenger cars that I assume would work on the trucks. Remember that Ford added reinforcements to their frame because the weight of the tank caused the frames crack. You would probably have better luck getting your answer on HAMB, http://www.jalopyjournal.com/forum/f...ssage-board.5/ , or reachable from the "Hot Roads and Customs" Forum on this site.
Charlie Stephens
Old 06-14-2016, 11:19 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
UNDERSEAT tanks are SCARY! Chiefs' friend burned to death, when he rolled his Old Dodge pickup.
Bill Sad
"THE ASSISTANT GURU OF STUFF"
