Old 05-23-2016, 04:33 PM   #1
raybee
Default Model B commercial intake manifold
I have a Model B commercial intake manifold that appears exactly as a Model A. The only difference is that it has 1.2 in. never drilled throat. The carb mounting holes are parallel to engine. Has anyone ever seen one like this? I read a post on intakes awhile back, and one like this was not mentioned, or pictured. Any info is appreciated. Thanks Ray
raybee is offline   Reply With Quote
Old 05-23-2016, 04:38 PM   #2
Bob C
Default Re: Model B commercial intake manifold
There is some info on Vince's site. http://www.fordgarage.com/pages/Bintakevariation.htm
Bob
Old 05-23-2016, 05:03 PM   #3
raybee
The one that I have is not pictured on that site. It has no vacuum clutch port. It appears exactly like a Model A, only has Model B size throat, again never drilled. This came from a late commercial Model B, as it had the late crank. Thanks Ray
Old 05-23-2016, 08:01 PM   #4
Charlie Stephens
Ray,
I will take the bait. What is a "commercial Model B" (do you mean BB?)? I thought the same engine was used in cars and trucks, of course it evolved over time. How about a picture?
Charlie Stephens
Old 05-23-2016, 08:17 PM   #5
raybee
By commercial , I should have said industrial. As were used on combines, water pumps, and other industrial equipment. Ray
Old 05-23-2016, 09:38 PM   #6
James Rogers
James Rogers's Avatar
A picture would be most helpful.
Old 05-24-2016, 10:09 PM   #7
raybee
As I noted earlier, it appears exactly like a Model A intake, only difference is 1.2 inch non drilled throat. I think most Model A guys know what a Model A intake looks like. Yes, I do not know how to post pictures, but would like to know if anyone has ever heard of one, Thanks Ray
Old 05-24-2016, 11:24 PM   #8
1930artdeco
1930artdeco's Avatar
Hi Ray,
Here is I think I know of Model B I takes. They have slight angles to them where as a models is curved smoothly. Also the mounting holes are at a slight angle away from the engine if I remember correctly. To me it sounds like bored out A manifold was attached to aB motor. I could be wrong though.
For pictures: go to advanced at the bottom when you want to reply to a thread. At the bottom you will see a line that says something like manage attachments. Click on that and a little window will pop up where you can upload pics from your computer.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-25-2016, 09:09 AM   #9
Binger
Binger's Avatar
I would like to see some pictures too. I have some old combine A engine parts floating around the shop and I wonder if I may have one in the pile. I have a governor that mounts off the timing gear and a different exhaust manifold. I wonder if there is an intake with it all. I will go and look after work and see if I might have one.
Binger is offline   Reply With Quote
Old 05-25-2016, 02:32 PM   #10
raybee
I will try to get some pictures, and see if I can get them posted. Outward appearance is exactly like a Model A. Only difference is throat bore size, it measures 1.2 in. It has not been bored, as it is still rough cast on the inside. It is curved like a Model A and the carb mount is not angled outward, but parallel to block. Ray
