Old 05-19-2016, 04:49 AM   #1
kbinde2
kbinde2's Avatar
Default '29 Firewall
Could a '29 Coupe owner post a picture of a stock (or nearly so) firewall.?
ie.. vacuum line fitting, speedo grommet, etc.. I think I have some "extra" holes.!!
Thanks.. kb
kbinde2 is offline   Reply With Quote
Old 05-24-2016, 04:04 PM   #2
kbinde2
kbinde2's Avatar
Default Re: '29 Firewall
Re-requested..
Old 05-24-2016, 06:01 PM   #3
Charlie Stephens
You might have better response if you posted a picture of yours with the holes you are concerned about. Put pieces of tape with numbers next the holes you are concerned about.
Charlie Stephens
Old 05-24-2016, 06:59 PM   #4
wrndln
Here is a picture of the firewall of my 29 phaeton. I am pretty sure the holes in it are only Ford punched. I believe the vacuum line hole is in the lower right corner of the gas tank front sheetmetal (second picture). The second picture is the gas tank for my 29 CCPU that doesn't use a vacuum wiper, as pickups use manual wipers. Normally there are extra holes including a crudely made manifold heater hole about 2" or 2 1/2" in diameter on the passenger side. Hope this helps.
Rusty Nelson
Old 05-24-2016, 09:25 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I had posted pictures of my 28 firewall, but can't find them now.
Here's a link to another of Rusty's firewalls.
https://www.fordbarn.com/forum/showth...rewall+picture
Old 05-25-2016, 03:45 PM   #6
kbinde2
kbinde2's Avatar
I did fill the hole "butchered" for the manifold heater, and I can locate fuel sediment line and speedo grommet.. any extra.?
Old 05-25-2016, 04:24 PM   #7
wrndln
You have 2 holes that weren't factory punched. In the grouping of 3 holes on the passenger side the only hole that should be there is the one that looks like a D, directly above the choke hole. A D nut (10-32) should be installed in the hole for a small clamp to secure the speedometer cable I believe. The D nut should be installed from the outside, unlike the one on the drivers side that is installed from the inside.
Rusty Nelson
Old 05-25-2016, 05:54 PM   #8
kbinde2
kbinde2's Avatar
Thanks Rusty.. this forum and it's members, give those of us "newer" to the affliction, hope and direction.. to go on.!
kb
