Old 05-08-2016, 03:11 PM   #1
Tgibby
Default 41 ford ignition switch
locked switch wont turn any help
Tgibby is offline   Reply With Quote
Old 05-08-2016, 03:16 PM   #2
JSeery
JSeery's Avatar
Default Re: 41 ford ignition switch
You don't have to post new each time, just type something like BTT on you old post to take it Back To the Top. Did you try the suggestion about the steering wheel pushing hard against the column lock? Try wiggling the wheel back and forth which turning the key. And take it easy as these keys break off easily.
Old 05-08-2016, 03:21 PM   #3
JSeery
JSeery's Avatar
Saw the other post answer, see how confusing this gets with multiple post on the same subject!! There are several Lock Smiths on this site, but it is Mother's Day weekend so may take a while for them to respond.
Old 05-08-2016, 03:24 PM   #4
4dFord/SC
4dFord/SC's Avatar
Wiggle the wheel back and forth as you try to turn the key.
4dFord/SC is offline   Reply With Quote
Old 05-08-2016, 04:57 PM   #5
TJ
TJ's Avatar
Make sure the key is all the way into the lock. Jiggle the wheel as others have suggested
Old 05-10-2016, 06:06 AM   #6
Tgibby
have tried wiggling,jiggling and forcing still no luck any other thoughts
Old 05-10-2016, 06:38 AM   #7
JSeery
JSeery's Avatar
Hopefully one of the Locksmith guys will post!
