Old 05-05-2016, 07:02 PM   #1
larry harding
Default running boards problem solved
i posted a question a few days ago about removing the old rubber from running boards. i got no response so i experimented a bit. i clamped the board to a metal table with half of it hanging off(don't try this on the boss ladys kitchen table) i used an old plumbing torch, a propane torch or even a heat gun might work. as i heated from underneath i used a scraper to literaly just roll the old rubber of easily. i just kept moving the torch around as it softened up the old rubber that was hard as a rock at room temperature. i thought i would pass this along.
larry harding is offline   Reply With Quote
