Old 04-19-2016, 04:47 PM   #1
Ford Freak
Default Flywheel Removal
Hi Guys ! I have a 9" clutch behind a 59 AB . Can I remove the flywheel without dropping the oil pan Thanks in advance ! - FF
Ford Freak is offline   Reply With Quote
Old 04-19-2016, 05:04 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Flywheel Removal
No.
Old 04-19-2016, 06:26 PM   #3
Ford Freak
Originally Posted by deuce_roadster View Post
No.
Not what I wanted to hear , but thanks . - FF
Old 04-19-2016, 06:30 PM   #4
JSeery
JSeery's Avatar
It's the flywheel itself that will not clear.
Old 04-19-2016, 07:23 PM   #5
deuce_roadster
Look at it as an opportunity to put a new pan gasket on!
Old 04-19-2016, 07:40 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
The answer would be no....UNLESS....you were lucky enough to have a two piece oil pan that was originally used on trucks. The rear piece, under the flywheel is removable, allowing access to the clutch, pressure plate, and flywheel.
John
Old 04-19-2016, 08:20 PM   #7
Ford Freak
No , I'm not " lucky enough " LOL !!
