Old 04-16-2016, 11:31 AM   #1
grovesmr
Default Part check 35pu?
Inner radiator splash pan, looks like it's a match to what's on grandpa's 35 roadster, wondering if it's a match for my 35 pickup. This is the pan between the rad and cross member and not the rad and grille that I know is different
grovesmr is offline   Reply With Quote
Old 04-17-2016, 10:22 AM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Part check 35pu?
The same.
Old 04-17-2016, 10:58 AM   #3
grovesmr
Originally Posted by Lawson Cox View Post
The same.
Thanks!
Old 04-18-2016, 07:07 AM   #4
oldandtired
grovesmr...The picture you posted is interesting to me. The part you asked about does indeed work on a 35 pickup. That particular part had an early and a late if I remember correctly, with the early one not having the hole in it that is pictured. What is puzzling to me is that the picture appears to show two mounting holes on the radiator mounting bracket. I thought the 35 only had one hole and the 36 and later had two holes for mounting the radiator. Maybe someone else could weigh in.
oldandtired is offline   Reply With Quote
Old 04-18-2016, 07:41 AM   #5
grovesmr
youre right, the frame is a 36 but i have a 35 grille shell so ill using that and that's why i asked what i did. good eye though.
