Re: Part check 35pu?
grovesmr...The picture you posted is interesting to me. The part you asked about does indeed work on a 35 pickup. That particular part had an early and a late if I remember correctly, with the early one not having the hole in it that is pictured. What is puzzling to me is that the picture appears to show two mounting holes on the radiator mounting bracket. I thought the 35 only had one hole and the 36 and later had two holes for mounting the radiator. Maybe someone else could weigh in.
