#1 |
I'm in the process of returning my headlights to stock configuration. I ordered some new radiator shell grommets from Brattons, they are quite a bit smaller in diameter than the ones coming out, and the center hole is considerably larger. The conduit is not held tight at all. Is this common? Should I look for grommets elsewhere?
