As usual, original parts work very well. The repro headlight socket parts do not work, period. They short out.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
The repro parts I have seem pretty darn good, everything looks as though it should work, but I can certainly see why they would be problematic. I repaired major appliances for over 40 years, worked with high current, high voltage connections all day every day. The stock connections appear to be something easy to install on the assembly line more than something designed to be trouble free long term. I checked the ground from the headlight bowl to the engine block and frame, and it's rock solid so I don't think I'll bother with a ground wire.
I looked all over for some pictures of the headlight lens installation but couldn't find anything in the books I have or on the internet including the Barn's search function. Scratched my head for a bit figuring out the lens retainer clips.
![]() I assume this is correct? |
