Old 04-10-2016, 01:41 PM   #1
FrankWest
FrankWest's Avatar
Default permetex "make a gasket" for oil pan gasket creation
Has anyone used the Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker compound to make a oil pan gasket rather than use a cork gasket?
FrankWest is offline   Reply With Quote
Old 04-10-2016, 01:44 PM   #2
Bill's Auto Works
Bill's Auto Works's Avatar
Default Re: permetex "make a gasket" for oil pan gasket creation
All the car manufacturers changed to Permatex instead of actual gaskets years ago & it works quite well. Just make sure both surfaces are clean, dry & straight. Usually a 1/4 inch bead is what works best.
Bill
Your QUALITY Ford Barn Transporter- Open or Enclosed.
Bill's Auto Works Est. 1983 & Still Going Strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Amb. Cust. Lemans
1964 Pontiac Grand Prix 2 DR HT
1966 Pontiac Catalina Conv
1966 AMC Ambassador DPL 2 DR HT
1966 AMC Ambassador Cust 2DR HT
1967 AMC Marlin
1967 Toronado
1973 Chevy Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS 2 DR Coupe
2007 Cadillac XLR-V Supercharged Roadster
2008 Southern Customs Avalanche
Bill's Auto Works is offline   Reply With Quote
Old 04-10-2016, 02:51 PM   #3
1Tudoor
1Tudoor's Avatar
You're still going to need the front and rear pan seals .
1Tudoor is offline   Reply With Quote
Old 04-10-2016, 03:16 PM   #4
Marleysurf
Yes please let me know how it works! I need to drop my pan and clean it out and install a new gasket soon!
Marleysurf is offline   Reply With Quote
Old 04-10-2016, 05:01 PM   #5
Jordan
Jordan's Avatar
yes I have used it multiple times. It works so well, I bet you could take all the bolts out and the gasket maker would still hold the pan in place while driving. It's a bear to get off the pan off again tho.
Cowtown A's
Jordan is offline   Reply With Quote
Old 04-10-2016, 07:26 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, I have used it on newer cars, but since I want the pan to come off again to check the bearings, I'd prefer to use the gasket and put a light coat of grease on one side of it.
