Old 03-21-2016, 08:20 PM   #1
Tom Smith
Default 35' Truck Headlight Rim Problem
Working on installing the lens rings. Purchased new ones and cannot get the latch to go over the retainers. I compared them to an original, the only difference I can find is the length of the latch bracket. I found that the original is approximate .100 longer than the new ones. The original latches fine. Did I receive wrong parts? Anyone have any suggestions.
Tom Smith is offline   Reply With Quote
Old 03-21-2016, 08:55 PM   #2
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default Re: 35' Truck Headlight Rim Problem
Did the new parts come with a tag that says "Vintique"?
Sometimes its a label that has the seller's label plastered over the top of it.
Scott H in Wheaton is offline   Reply With Quote
Old 03-22-2016, 08:05 AM   #3
Tom Smith
I have had the glass installed inn them for a while, I did find the wrapper from the glass and they were from Vintique. Not positive they were from them also. They were purchased from a NY supplier. Is Vintique the only supplier of this part? Suggestions welcome.
Old 03-23-2016, 10:56 PM   #4
bbook
I had the same problem with rings for my 36 truck from Bob Drake. I removed the rubber gasket in favor of cork, bent the fork on the bucket a little, and did some filing on the mating surface of the bucket to get them to go on. Repop parts often require a little persuasion to fit.
Keep trying. You will get them on.
bbook is offline   Reply With Quote
Old 03-24-2016, 03:24 PM   #5
Tom Smith
Thank you all, I ended up bending out the tabs some, to get the latch past the end of tab. The bracket that Bob Drake is is using is the same as a Model A part. The length to the pivot point is short by .100. If was corrected by the supplier no one would have this problem. I also did use the cork seal on the reflector.
