Old 03-06-2016, 11:08 AM   #1
oneoldtruckguy
Default 1940 ford rearend question
I need a rear end for a 40 ford coupe roller. What rear ends will work size wize that I can just put under the car and still have 40 wheel bolt on? Thanks Ford Barn!
oneoldtruckguy is offline   Reply With Quote
Old 03-06-2016, 12:01 PM   #2
19Fordy
19Fordy's Avatar
Default Re: 1940 ford rearend question
The WMS to WMS of a stock 40 Ford rear is 59.5 inches.
1966- 77 Bronco
1935-48 Ford
http://www.roadkillcustoms.com/hot-r...#axzz428vWl4m5
Old 03-06-2016, 12:03 PM   #3
flatjack9
flatjack9's Avatar
36 to 39 would need a drum change as they are the wide bolt pattern.
Old 03-06-2016, 12:36 PM   #4
19Fordy
19Fordy's Avatar
Opps! Thanks for the correction.
Old 03-06-2016, 01:57 PM   #5
Newc
Newc's Avatar
hi all; Just a note on the Bronco rears. The backing plates are indexed [rotated] for a high pinion angle and when you set up a flatter pinon angle ,it leave the wheel cylinders on an angle and trickier to then bled the air out. Newc
